RCmag :: Voir le sujet - News Chargeur LRP Pulsar Pro charger
philippe27
MessagePosté le: 08.01.2016, 10:24:42    Sujet du message: News Chargeur LRP Pulsar Pro charger Répondre en citant
This is an excerpt from the January 2016 edition of LRP owner Jürgen Lauterbach's monthly column posted to the brand's website:
Our LRP charger line has just gotten a facelift. The new LRP Pulsar Pro builds on the success of chargers like Pulsar Touch and Quadra Competition. Due to its great versatility, it can be used for all R/C flight, car and boat battery types. Also outlaw LiPo batteries are no problem at all. The up to 15 battery cells can be charged with up to 10A.
You can either power the charger with AC 100-240V or with DC Input (11-18V). The correct connector for the wall socket of your country is already mounted. The large terminals enable easy connection to your car battery. No matter where you are, you can rest assured that your batteries will be charged. The USB exit has also been improved to 2.1A output. The balancer connector has been switched to a XHR connector that matches the connector of all our LRP batteries. Unfortunately, there are still accidents happening when LiPos are charged the wrong way. To decrease this risk, we have implemented a safety feature into the software that displays an overview of all set parameters before the charging can be activated. I think this will really help avoid the risk of costly charging accidents.
