philippe27 Champion du monde
Posté le: 01.02.2013, 10:12:55 Sujet du message: Moteur Seiki SR21TRS is a 5+2 port competition Buggy |
Soar Seiki SR21TRS is a 5+2 port competition Buggy engine. The SR21TRS 5+2 port sleeve and a 14mm long stroke cranckshaft significantly reduces fuel consumption without affecting the power output providing the perfect balance of power and run time. The low CG and light weight head contributes to improved car control and performance thanks to it 9 fin optimized cooling head.
Proven 7 port sleeve design provides optimum engine performance with smooth, crisp acceleration and fuel efficiently. Turbo slide crankshaft made from the highest grade steel using state of the art manufacturing for precision and balance. Cranckshaft is hardened for a maximum hardness for extended life without compromising toughness.
http://www.soarseiki.com/sr21trs-tuned-edition-image-gallery/
hese specifications have been tested in our labs, using specific benchmarks to ensure our products quality. All our materials guarantee the accomplishment of the specifications detailed in the table below.
SR21TRS Specifications Spec Info
Displacement: 3.45 cc
Bore: 16.26mm
Stroke: 16.80mm
Practical R.P.M 3000-40000 RPM
Power Output: 2.58PS-39900RPM
Weight: 355gr
Ports: 5 + 2 ports
Sleeve: ABC
Crankshaft Diameter: 14mm
Glow Pug tipe: Turbo
Exhaust: Rear
Carburator size: 8mm Variable
Cranckcase material: Aluminium
http://www.soarseiki.com/sr21trs-tuned-edition-spare-parts/
amontintin Champion du monde
Posté le: 01.02.2013, 12:10:19 Sujet du message: |
j'ai l'impression de voir de l'alpha ou de l'argus _________________ amontintin lecerveaulent.........très lent, mais a quand même trouvé un sponsors.....mdr
Posté le: 01.02.2013, 19:21:13 Sujet du message: |
Maximax Expert**
Posté le: 01.02.2013, 20:59:17 Sujet du message: |
celui avec la pate vilo , on dirait le vilo du Lutz !! |
Posté le: 01.02.2013, 21:12:59 Sujet du message: |
la photo du lutz par redrc
frikan Expert**
Posté le: 01.02.2013, 21:44:24 Sujet du message: |
Très jolie pièces mais la sa devient compliquer avec toutes ses marques et sous marques de moteurs |
Maximax Expert**
Posté le: 01.02.2013, 22:10:19 Sujet du message: |
Carrément !! la meme photo en plus lol |
Maximax Expert**
Posté le: 01.02.2013, 22:14:14 Sujet du message: |
il a l'air sympa ce petit moteur sinon !! |
korc Découverte
Posté le: 01.02.2013, 22:40:43 Sujet du message: |
carter de l'Argus , chemise piston de l'A852 et vilo du lutz
Reste plus qu'à usiner une culasse |
Posté le: 05.10.2013, 12:43:44 Sujet du message: |
Soar Seiki SR2152B is a 5+2 port competition Buggy engine. The SR2152B 5+2 port sleeve and a 14mm long stroke cranckshaft significantly reduces fuel consumption without affecting the power output providing the perfect balance of power and run time. The low CG and light weight head contributes to improved car control and performance thanks to it 9 fin optimized cooling head.
Proven 7 port sleeve design provides optimum engine performance with smooth, crisp acceleration and fuel efficiently. Turbo slide crankshaft made from the highest grade steel using state of the art manufacturing for precision and balance. Cranckshaft is hardened for a maximum hardness for extended life without compromising toughness. |
Fred16 Expert*
Posté le: 07.10.2013, 08:02:01 Sujet du message: |
Même ensemble de piston/bielle que mon alpha club racer |
