RCmag :: Voir le sujet - Chargeur Mega Power Gemini-3020i EVO 1000W
philippe27
MessagePosté le: 17.01.2012, 20:57:08    Sujet du message: Chargeur Mega Power Gemini-3020i EVO 1000W Répondre en citant
Mega Power Gemini-3020i EVO 1000W Power Charger
Specification:http://www.hawk-rc.net/image/cache/data/BatteryCharger/MP2014c-500x500.jpg
Fully 12 bits digital control with uncompromised precision and speed of charging.
Two batteries of different specifications can be charged at the same time .
Battery Capacity of Each charging ports : lithium polymer (Li-Poly 1-7 S), lithium-ion (Li-ion 1-7 S), lithium iron (Li-Fe 1-7 S) and nickel-cadmium (Ni-Cd 1 ~ 18 cell), nickel-hydrogen (Ni-MH 1 ~ 18 cell, lead accumulator batteries (Pb 2~24 V)
Large 2.9" LCD display dual ports data in single screen
http://www.log-viewer.com/?gclid=CJmHxbjjh6gCFQTabgodK2shqQ
SPECIFICATION
The Gemini 3020i Evo is the ultimate choice for the professional modeller. With twin 500 watt chargers, the Gemini can charge two separate packs at up to 20 Amps per output!
Key Features:
• Easy to use user interface
• 11~28V DC Input
• 2 x 0.1~20A Charging (max 500W per channel - Requires 28V DC input for 500W opperation)
• 2 x 0.1~10A Discharging (max 50W per channel)
• 2 x 1~7 Cell Lithium - Charge, Discharge and Storage
• 2 x 1~18 Cell NiCd/NiMh - Charge, Discharge and Cycle
• 2 x 2~24V Lead Acid - Charge and Discharge
• NiCd/NiMh - Automatic, Normal, Linear and Reflex Charge
• NiCd/NiMh - Adjustable Trickle Charge
• NiCd/NiMh - Adjustable Peak Sensitivity
• Lithium - Selectable Charge Rate Limit (up to 5C)
• Lithium - TCS (Terminal Capacity Selection)
• Lithium - Adjustable maximum cell voltage
• Safety Timer Cut-off
• Maximum Capacity Cut-off
• 2 x Temperature Sensor Input (sensor optional)
• 2 x 20 Battery Memories
• 128 x 64 Pixel Blue Backlit LCD
• 2 x 4mm Output Sockets
• 2 x 7 Cell JST-EH Balance Port with 7 Cell adaptor boards for JST-XH and FP/TP
• 10 Melodies (selectable for each channel)
