SPECIFICATIONS:
Dead band: 2μs
Control System: +Pulse Width Control
Working frequence: 1520μs / 330hz
Operating Voltage: DC6.0~8.6 V
Operating Temperature Range: -10 to + 600C
Operating Speed (6.0V): 0.13sec/60 degrees at no load
Operating Speed (7.4V): 0.11 sec/60 degrees at no load
Stall Torque (4.8V): 21.53 kg.cm (299.05 oz/in)
Stall Torque (7.4V): 24.35 kg.cm (338.22 oz/in)
Potentiometer Drive: Direct Drive
Dimensions: 40.5X20.2X40.2mm /1.59 X0.80X1.42 in
Weight: 63.5 g (2.24oz)
Connector Wire Length: JR 265 mm (10.43in)
http://kingmaxhobby.com/_d272961823.htm
SPECIFICATIONS:
Dead band: 2μs
Operating Speed (6.0V): 0.11sec/60 degrees at no load
Operating Speed (7.4V): 0.09 sec/60 degrees at no load
Stall Torque (4.8V): 11.62 kg.cm (161.40 oz/in)
Stall Torque (7.4V): 15.22kg.cm (211.41oz/in)
http://kingmaxhobby.com/_d272961950.htm
source membre rcmag
