Posté le: 22.02.2011, 22:57:30 Sujet du message: Kit Big bore amortisseur 1/16th REVO (Option exotekracing)
The only BIG BORE shocks on the market for the 1/16th REVO and the best shocks period!
Polished gun metal anodized alloy construction with threaded tops, bodies and bottoms caps for easy maintenance, adjustability and durability. Silicone o-ring with silicone top bladder insure leak free yet silky smooth operation.
Pre-assembled bodies includes 80 weight oil and heavy duty springs. Just top off the shock oil and complete the final assembly!
Also included are polished alloy shock mounts and spring retainers as well as adjustable turnbuckle set for the front rockers. Hardware and instructions included also (requires 2mm hex wrench)
