Posté le: 03.07.2010, 19:58:46 Sujet du message: Couverture chauffante pour moteur à rodager
a voir si le sujet a déjà été traité si non post a supprimer
http://www.youtube.com/watch?v=9e4aqGQGVRI&feature=player_embedded http://www.youtube.com/watch?v=H9mXj11q_go&feature=related
Competition Heat .21 R/C racing engine heater is extremely efficient and has excellent heat transfer, it will uniformly heat all critical internals, crank, con rod, piston and sleeve. It will properly pre-heat your R/C racing engine to 180-200 degrees F in 10 to 15 minutes (depending on ambient temperature). Competition Heat uses the most advanced materials and technology available to provide serious racers with the ultimate in R/C racing engine life and performance.
FEATURES AND BENEFITS
* Properly and effectively heats all critical parts
* Misconception. You should only pre-heat you’re racing engine in cool weather is false. You should pre-heat your high performance R/C racing engine every time before you start it.
* Cover is made of heat resistant and fireproof material. Helps insulate R/C racing engine and you can safely remove heater from engine.
* Heating element is moisture and chemical resistant
* High temp Velcro adjustable cover fits all .21 R/C racing engines
* Built in quick connect/disconnect connector. You can disconnect and break in you R/C racing engine in the car with the heater attached.
* Glow plug igniter and temperature access port allows you to start your R/C racing engine while heater is in operation.
* Extremely efficient, only 50 watts 110 Volts. Track owners and operators will benefit from its efficiency.
* Distributes heat so effectively it will heat chassis and diffs
* 30% to 40% of an R/C racing engines life is spent simply trying to bring it up to temperature. Nothing is harder on these high performance R/C racing engines than a cold start and constant high revs to build heat. This results in excessive engine wear and stress on piston, con rod and crank. The Competition Heat R/C racing engine heater is capable of doubling engine life and increasing overall performance.
* Learning to break in and properly tune an R/C racing engine can be frustrating. The Competition Heat .21 R/C racing engine heater will greatly reduce the learning curve and frustration by properly and consistently pre-heating your high performance R/C racing engine every time, making it easier to start and tune.
* Hands free operation
* Most importantly, it will pay for itself by increasing engine life and performance.
