super ces options belles pièces
par contre je vois pas trop l'intérêt d'avoir fait un cardan homocinétique
hormis peut être d'avoir deux cardan identique
car je pense que l'angle de ces cardans centraux est acceptable tel que !!!!
Hot Bodies have released a number of new options for the D8, D8T and Ve8. Starting with these durable and lightweight billet aluminium rear hub carriers. They come in the standard 0 degree but with the option of moving the hub forward or backward in the arm with finer shims and a narrower overall width. Also new is the front spindle carriers that come with 10 degree caster. This part gives you more upper link adjustments with more mounting holes and by turning the ball vertical. To further strenthen the front end, these billet aluminum front spindles are almost indestructible without gaining a bunch of weight. A new DCJ center drive shaft smoothes out the harsh angle of the front/center drive shaft, which decreases friction giving you more power and increasing the life of that part. Finally for the Ve8 only are front and rear black anodised aluminium skid plates.
