Sanwa will soon release a new mid-level radio system called the MT-44, which replaces the popular MT-4S. The completely-new case design houses a large, white back-lit display, and allows for adjustment of the handle and steering wheel position. The unit will be compatible with Sanwa’s FH3 and FH4T telemetry receivers supporting SHR and SRR modulation, and will only require 3 AAA batteries or a single Lithium-cell pack for power. A November release date is expected.
Bonjour, au moment où l'on règle le type de voiture, de servo et pour le vario il y a high class esc, low class esc et sv je crois, que faut il mettre pour un esc hobbywing xr8 140 ? Merci.
