RCmag :: Voir le sujet - Servo OS speed R1/B1/T1 (1/8 et 1/10)
philippe27
MessagePosté le: 26.02.2017, 18:15:35    Sujet du message: Servo OS speed R1/B1/T1 (1/8 et 1/10) Répondre en citant
https://www.rc.futaba.co.jp/servo_car/collaboration/index.html
[img]Futaba and O.S. Speed have come together to release a trio of servos that racers will want to check out. The Speed T1 BLS571SV is low profile unit ideal for 1/10 on road applications and features ceramic bearings, aluminum top and mid-section case, hardened gears and has great specs; Speed 0.08sec / 60 ° and torque 11kg-cm at 7.4V. The Speed R1 BLS371SV is ideal for 1/8 on road applications with a hybrid final stage gear, ceramic bearings, aluminum upper and middle case with great Speed 0.10sec / 60 ° and torque 19.0kg-cm at 7.4V. The Speed B1 S9373SV for 1/8 off road use has an all aluminum case, ceramic bearings, a hybrid final stage gear and is fast with a speed of 0.06sec / 60 ° and torque rated at 24.6kg-cm at 7.4V.[/img]
