RCmag :: Voir le sujet - Chargeur Hitec : X2 AC Plus 2 Port AC/DC Multi-Charger
philippe27
MessagePosté le: 15.06.2015, 09:25:22    Sujet du message: Chargeur Hitec : X2 AC Plus 2 Port AC/DC Multi-Charger Répondre en citant
Product Description
The X2 AC Plus charger offers expanded capacity and compatibility in a portable and compact package. Dual inputs afford flexible battery charging at home and in the field. And our innovative power distribution mode lets you efficiently assign output power based on individual battery requirements. Capable of charging all battery chemistries, the X2 AC Plus has a built-in 10-amp power supply, internal balancing circuits and 10 different charge/discharge profiles, making it an essential tool for all hobbyists. You can even utilize your smartphone for remote control via an optional WiFi module. Hitec brings the future of charging to your fingertips!
Features
Twin Channel Charger with Two Independent Circuits
Power Distribution Circuit for Ultimate Flexibility in AC Mode
Example 1: Channel A – 20W, then Channel B – 80W for a Total 100W Power
Example 2: Channel A – 70W, then Channel B – 30W for a Total 100W Power
Charges NiMH, NiCd, LiPo, LiHV, LiFe, Li-Ion, and Lead Acid Batteries
Built-in 10-Amp Power Supply
Uses Either 11-18V DC or 100-240V AC Power Sources
Adjustable Charge Current Rate of 0.1 – 10.0 Amps Each Port
Internal Balancing Circuits
10 Programmable Profile Settings
Specifications
NiCd/NiMH Cell Count: 1-15 cells
LiPo/LiHV/Li-Ion/LiFe Cell Count: 1-6 cells
Pb voltage: 2-20 volts
Charge Current Range: 0.1-10.0 amps
Maximum Charge Output: AC 100W / DC 100W x 2
http://hitecrcd.com/products/chargers/acdc-chargers/x2-ac-plus-2-port-acdc-multi-charger/product
http://hitecrcd.com/products/chargers/charging-accessories/optional-wifi-module/product
Product Description
Utilize your smartphone for remote control functionality via the optional WiFi module.
Features
Compatible with the X2 AC Plus Charger
View, Change & Customize your X2 AC Plus Options via Smartphone
Supports Both iOS and Android Devices
http://hitecrcd.com/images/products/pdf/395_X2_AC+_Manual_WEB.pdf
