RCmag :: Voir le sujet - Chargeur Dynamite Passport ULTRA 100W
philippe27
MessagePosté le: 12.12.2014, 07:01:06    Sujet du message: Chargeur Dynamite Passport ULTRA 100W Répondre en citant
Dynamite Passport ULTRA 100W - HORIZON HOBBY
Key Features
100W powerful charging and 20 Battery Memory
0.1 to 10 amps for quick recharging
Chargers NiMH/LiPo/LiFe/LiIon/NiMH/NiCd and Pb
1-6S LiPo Balancing
2.1A USB port for charging smart/mobile devices
Includes an insulated banana to EC3™ battery adapter and a JST-XH balance adapter
Overview
The Passport Ultra charger is a rugged, small footprint, multi-chemistry, AC/DC battery charger with a fully-functional touchscreen user interface designed for quick charging of all your hobby batteries. The Passport Ultra is ideal for anyone that wants to spend less time charging and more time enjoying their hobby. AC powered and featuring a wide range of selectable charge/discharge currents and features to fit your batteries needs, the Passport Ultra is capable of charging surface, air and marine of any chemistry and is backed by a Dynamite 5-year warranty.
Power Input: 100-240V AC or 11-18V DC
Battery Type: LiFe/LiIon/LiPo/NiCd/NiMH/Pb
Charge Rate: 0.1 – 10.0A / 100W
Selectable Charge Rate: Yes - Incremental (0.1A Increments)
Discharge: Yes
Discharge Rate: 0.1 – 5.0A / 25W
Input Connector: AC cord, detachable, North American plug, DC cord, detachable, alligator clips
Output Connector: Banana Plug
Integrated Balancing: Yes - Internal Balancer & External Adapter
Battery Balance Connector: JST_XH
Display: TFT Color Touch Screen, 400 x 240 Pixel
Voltage Meter: Yes – on main LCD display
Ampere Meter: Yes – on main LCD display
PC Connectivity: Yes – USB
Model Memory: Yes - 20 battery settings
Software Updates: Yes – via USB port
PC Required: Yes
Battery Temperature Monitoring: Yes - Temperature Sensor not included
Thermal Protection: Yes
Reverse Polarity Protection: Yes
Short Circuit Protection: Yes
Over Current Protection: Yes
Low Input Voltage Protection: Yes
Safety Timer: Yes
Fuse: No
Peak Detection: Yes
Cooling Method: Fan
Length: 8.74 in (222mm)
Width: 6.89 in (175mm)
Height: 2.95 in (75mm)
http://www.horizonhobby.com/pdf/DYNC3000-Manual_FR.pdf
http://www.horizonhobby.com/passport-ultra-100w-acdc-touch-battery-charger-dync3000
Patti
MessagePosté le: 12.12.2014, 11:12:13    Sujet du message: Répondre en citant
Evolution des afficheurs chez DYNAMITE Smile
Un peu marre des 2 malheureuses petites lignes d'affichage présentes sur la plupart des modèles du marché. Enfin les choses bougent !
RiveraRiding
MessagePosté le: 12.12.2014, 12:30:36    Sujet du message: Répondre en citant
Bof, c'est surtout pour répondre au marketing des concurrents, voire donner envie de trouver une raison pour changer le sien, parce qu'en terme fonctionnel ca ne doit pas changer grand chose...
Patti
MessagePosté le: 12.12.2014, 20:10:40    Sujet du message: Répondre en citant
C'est malgré tout bien pratique d'avoir plus d'infos à l'affichage sans devoir faire défiler les différentes lignes.
Mais effectivement, ça donne envie de changer d'appareil !
