RCmag :: Voir le sujet - News Chargeurs Dynamite
philippe27
MessagePosté le: 09.10.2012, 22:09:37    Sujet du message: News Chargeurs Dynamite Répondre en citant
Passport Duo 400W Dual AC/DC Charger
Features
Interal AC power supply saves on space and doesn't require a separate external power supply
100-240V AC (50/60Hz) or 11-18V DC input voltage
Detachable AC power cord
200W charge power per output
25W discharge power per output
Short circuit, overcurrent, and reverse polarity protection
Low input voltage protection
Over temperature protection
Battery storage mode
IP33CW, IK07 environmental rating
Includes (2) insulated Banana to EC3™ battery adapter cables
Includes (2) JST-XH balance adapter boards
Optional high-current DC power cord available (DYN4012)
Charges LiPo/LiFe /Li-Ion (1-6 cells), NiMH/NiCD (1-15 cells )and Pb battery types
500W internal power supply ensures that full power output is available even while utilizing both charge outputs and all USB power options
0.1-10.0A adjustable charge current per output
Overview
The Dynamite® Passport™ Ultra Duo battery charger represents the pinnacle of premium, high-performance chargers. The one-of-a-kind Ultra Duo is the only 400W (200W x2) charger on the market with an internal high-capacity (500W) AC power supply. Now extremely fast charge times are possible thanks to the ability to charge at higher C rates, even on AC power! With dual 200W output capability, the Ultra Duo can charge low- to medium-capacity 3C Li-Po batteries in half the time it takes lower wattage/amperage chargers. In addition, the Ultra Duo resides within the family of Dynamite® Passport™ chargers, meaning you get the full gamut of charging features, including the ability to charge virtually all battery types, a digital dot matrix display, and an easy-to-use jog dial navigation.
Articles, Reviews and Links
Dynamite Vision Chargers Review
Understanding RC Batteries
Manuals
http://www.dynamiterc.com/ProdInfo/Files/DYN4300_Manual.pdf
Passport UltraLite 50W ACDC Charger Multi-Tool
Features
Independent Li-Po, Li-Fe, Li-Ion voltage checker / 2W discharger
Four high-intensity LED utility lights
1A USB charge port
Space saving design
Detachable AC and DC power cords
Rugged industrial plastic case
50W charge power
10W internal discharge power
Includes (1) insulated banana to EC3™ battery adapter cable
Includes (1) JST-XH balance adapter board
Overview
The Dynamite® Passport™ UltraLite 50W AC/DC handheld charger is far more than just your standard 50W AC/DC charger. Yes, it can charge and balance 1–6S Li-Po, Li-Fe and Li-Ion, as well as Ni-MH, Ni-CD, and Pb batteries — but that's just the beginning. The charger is a one-of-a-kind RC multi-tool that can be compared to a Swiss Army knife when it comes to utility. The UltraLite boasts four high-intensity LED lights to illuminate your workbench or pit area and a 1A USB charge port that can be used to charge an iPhone®/iPod® or any other USB charge-compatible device. Its unique case design makes it easy to hold in one hand while manipulating charge settings, while the pre-installed "kickstand" allows the charger to be positioned vertically or hung at the owner's discretion. Additionally, the charger has a built-in independent Li-Po/Li-Fe/Li-Ion battery voltage checker and discharger that allows users to check individual cell voltages to verify pack balance while charging another battery pack or when the charger is turned off. All these features are easily monitored thanks to their own three digit LED display.
Manuals
http://www.dynamiterc.com/ProdInfo/Files/DYN4103-Manual_FR.pdf
Chris38
MessagePosté le: 08.09.2013, 18:42:12    Sujet du message: Répondre en citant
Je recherche un chargeur de type multi-sorties, connaissez-vous cette marque en terme de suivi SAV par exemple, il présente pas mal d'avantage.
[url][/url]
Caractéristiques Chargeur Prophet Sport Quatro 4 x 100W AC/DC-EU :
Entrée: 100-240V AC et 12V DC
Charge : LiPo 6S :1-1-6S, LiFe, 1-8C NiMH
Taux de charge: 0.1A à 8.0A (par canal et par incréments progressifs 0.1A )
Connecteur d'entrée: cordon, détachable, connecteur Europe
Connecteur de sortie: Fiche banane vers EC3
Type de batterie: LiPo / LiFe / NiMH
Méthode de refroidissement: Ventilateur de refroidissement interne
Voltmètre: Oui - Le principal Écran LCD
Décharge: Aucun
Longueur: 270mm
Largeur: 190mm
Hauteur: 85mm
Protection contre les surcharges: Oui
Puissance de charge 100W par sortie
Conception Multi-chimie travaille avec Li-Po/Li-Fe & Ni-MH types de batteries
Capacité en cellules 1-6S Li-Po, 1-6S Li-Fe, 1-8C Ni-MH
Alimentation 500W fournit une alimentation supplémentaire pour les options d'alimentation auxiliaires, sans dégrader les 4 sorties de charge primaire
Courant de charge par canal Réglable 0,1-8.0A
Possibilité de charger différents types de piles à des courants différents en même temps
4 ventilateurs de refroidissement internes
Protection court-circuit
Protection contre les surintensités
Protection inversion de polarité
Faible tension d'entrée de protection
Protection contre la surchauffe
Comprend (4) connecteurs isolés banane-EC3™
Comprend (4) planches d'équilibrage (2-6S)JST XH
Alimentation CA et les cordons d'alimentation CC
Tension d'entrée AC 100-240 VAC (50/60Hz) ou 11-18V DC
Patti
MessagePosté le: 18.11.2014, 11:19:11    Sujet du message: Répondre en citant
Je recherche quelques remontées d'infos sur cette marque de chargeurs DYNAMITE , notamment le modèle présenté en intro, le PASSPORT ULTRA DUO
Ce modèle étant proposé par pas mal de sites de vpc, je suppose qu'il doit s'en vendre pas mal et que certains d'entre vous l'utilisent.
L'alimentation mixte et la puissance importante sont très tentantes.
Les tarifs ont également bien baissé sur cette référence, la rendant d'autant plus intéressante.
La qualité d'équilibrage est-elle au niveau de marques plus reconnues ? (HYPERION, GRAUPNER par ex)
Merci par avance.
MessagePosté le: 18.11.2014, 18:34:48    Sujet du message: Répondre en citant
on en voit quelque uns sur le RCMBT, j'ai pas eu de mauvais retours sur ces chargeurs
Patti
MessagePosté le: 18.11.2014, 20:58:07    Sujet du message: Répondre en citant
Merci pour ces précisions, c'est déjà un élément positif de savoir qu'il est fiable.
MessagePosté le: 18.11.2014, 21:36:51    Sujet du message: Répondre en citant
C'est une marque Horizon Hobby, donc pour le sav, pas de soucis OK!
Patti
MessagePosté le: 18.11.2014, 21:53:08    Sujet du message: Répondre en citant
Un bon SAV , c'est effecivement un gros plus Very Happy
La notice traduite en français ne m'apparait pas extraordinaire par contre, c'est imprimé tout petit et très serré, donc peu clair.
Le cordon 12V est à priori optionnel, c'est mesquin !
