Posté le: 28.09.2013, 11:36:46 Sujet du message: Contrôleur RSX Tekin !
Features:
– Billet aluminum heatsink housing
– Optional fan shroud system and high speed fan for maximum cooling
– Ultra-smooth and precise throttle and braking control
– Compatible with sensored/sensorless brushless and brushed motors
– High voltage programmable BEC
– EZ access HotWire programming port
– HotWire PC interface for advanced programming and updating
– On-board temperature indicator
– Gold-plated solder posts for easy wire replacement
Specifications:
– High voltage BEC (6.0v/7.4v)
– Controls: forward/brake/reverse
– Input voltage: 4-9 cells, 2S-3S LiPo
– BEC: 6.0v / 7.4v 5.5amps
– Timing profiles: 7 choices (on board)
– Dimensions: 25.4x33x12.9mm
– Weight: 42g _________________ Papy boomer
Elle est pas belle la vie.
Inscrit le: 02/11/2005 Messages: 6868 Localisation: Beaufort en vallée
Posté le: 28.09.2013, 11:41:50 Sujet du message:
je le veux, je le veux..... _________________ amontintin lecerveaulent.........très lent, mais a quand même trouvé un sponsors.....mdr
