RCmag :: Voir le sujet - New Servo Programmable Digit Freetech
philippe27
MessagePosté le: 10.02.2013, 16:32:17    Sujet du message: New Servo Programmable Digit Freetech Répondre en citant
Fi7621M: Standard 21.0 kg.cm HV Programmable Digital metal gears
-Standard digital Titanium gears servo、2BB
-Coreless motor、Aluminium middle hull
-Waterproof
-Operating Voltage: 2-cell Li-Po power
-Dead band width: 2usc
-Interface: (like JR)
-Wire length: 30cm
Servo programmable function
1. FAIL SAFE, On or Off
2. Direction of Rotation
3. Travel Speed
4. Servo Max Torque limit, and Punch
5. Center, End, and FAIL SAFE Point
6. Signal Pulse Set-Up
7. Stretch (Holding Power, Running Power, Acceleration and Deceleration)
8. Dead Band Width
9. Resolution Setup
10.“Save and Open” File Options
11. Reset Factory Default Data
12.Read and Write Servo Data
Power 7.4V 8.4V
Speed 0.16sec/60° 0.14sec/60°
Torque 17.8kg.cm/247.2 oz.in 21.0kg.cm/291.7 oz.in
Weight 56g(1.41oz)
Size 40.2*20.0*38.6mm
Application Air plane&Car&Boat&Robot
autres servos
http://www.feetechrc.com/category/all-products/standard-servo
Fi7617M: Standard 16.9kg.cm HV Programmable Digital metal gears
http://www.feetechrc.com/all-products/fi7617m-standard-16-9kg-cm-hv-programmable-digital-metal-gears-servo.html
ower 7.4V 8.4V
Speed 0.14sec/60° 0.12sec/60°
Torque 14.8kg.cm/205.5 oz.in 16.9kg.cm/234.7 oz.in
Weight 56g(1.41oz)
Fi7614M: Standard 14.5kg.cm HV Programmable Digital metal gears
http://www.feetechrc.com/all-products/fi7614m-standard-14-5kg-cm-hv-programmable-digital-metal-gears-servo.html
ower 7.4V 8.4V
Speed 0.13sec/60° 0.11sec/60°
Torque 12.1kg.cm/168.0 oz.in 14.5kg.cm/201.4oz.in
Weight 56g(1.41oz)
http://www.tradevv.com/chinasuppliers/fitec88
http://www.feetechrc.com/download-center/pc-software-for-ft-programmable-servo.html
http://www.feetechrc.com/wp-content/uploads/2012/10/SCPC-1-V1.1.pdf
philippe27
MessagePosté le: 10.02.2013, 16:36:37    Sujet du message: Répondre en citant
http://www.feetechrc.com/category/all-products/servo-parts
