Posté le: 08.02.2013, 20:43:47 Sujet du message: judicieux ce palonnier multi positions
FAST318B 3-in-1 Aluminium 23T Servo Arm (KO/Sanwa)
FAST319B 3-in-1 Aluminium 25T Servo Arm (Futaba)
FAST320B 3-in-1 Aluminium 24T Servo Arm (Hitec)
3-In-1 Servo Arm
Fastrax's new unique design 3-in-1 aluminium servo arm features a three way fit to suit all and every r/c car application. Choose from left or right 90° L-shaped arm or a straight double arm by simply rotating the top and bottom arms to the desired shape and direction. The machined lugs help secure the arms into place for a secure, solid fit. Once mounted to your servo the side clamp design ensures an ultra tight grip on the servo gear splines to avoid the chance of slippage and stripping.
