RCmag :: Voir le sujet - D8/ lightning hybride mod
speedy2
MessagePosté le: 03.03.2012, 11:29:57    Sujet du message: D8/ lightning hybride mod Répondre en citant
voici les pièces nécessaires pour faire un D8 à la Tess...
Ok guys, I've been getting ton of PM's about my D8/LP2 car so here's the scoop...
First off, the Shock towers were cut by SNR Graphite in SoCal as far as team development goes Josh, Mike gonzo, and I believe Jesse were running these towers for the last 8 months or so on the Ve8 with great success. The rear geometry is between the 112mm and Truggy tower the middle hole is the same as the inner hole on the Truggy tower. Also the front tower is slightly wider and lower than stock plus you get 2 new camber positions on both towers.
you can purchase the towers direct from SNRgraphite.com
http://www.snrgraphite.com/index.php?main_page=index&cPath=25&zenid=a4f160337a12bf46a85a0642be4a5167
And Last but least, here is the a complete list of the parts you must purchase to build a D8/LP2 hybrid.
Rear parts
TKR20042 (Tekno RC rear 92.5mm axle set)
C8077-1
C8116
C8015
C8010-1
c8013
Front parts
c8017 (you use a 5x51mm turnbuckle as a camber link)
C8010-1
C8116
c8011-1
c8119
c8078
c8081 or c8081-1
c8014
c8013
c8005-1
C8134
HBS67174 (92mm WCE axles)
8x16 bearings (4 pieces)
