philippe27 Champion du monde
![](modules/Forums/images/avatars/1685.gif)
Posté le: 23.07.2011, 13:23:30 Sujet du message: new aluminum double-effect shock pistons |
The new aluminum double-effect shock pistons for Kyosho, Hot Bodies and Gs Race cars are really very effective.
The 15mm external diameter is perfect for the cylinder barrel of the above mentioned models, assuring smoothness and extreme precision.
The 16mm external diameter is perfect for the cylinder barrel of the above mentioned models, assuring smoothness and extreme precision.
The innovation is the anti-sinking system, that is an o-ring placed on the external part of the pumping unit; the nose cone holes streamline the silicon oil flow towards the latter, which opens when the car encounter deep holes or has to spring. In this way the model car never hits the ground with the chassis while keeping a regular attitude.
Even swifter and more regular cars thanks to this new part, a must-have for the best pilots.
![](http://www.fioroni.com/contenuti/news/NEWS%20OT-UR328-B.JPG) |
smagrad Expert*
![](modules/Forums/images/avatars/Perso/Masselette_blasonauvergnedh2.png)
Posté le: 23.07.2011, 17:01:41 Sujet du message: |
salut a tous
en cours d'essai sur mon DNX 408
pour le moment c'est pas mal , a approfondir des que la meteo est d'accord et à la coupe des ligues .
dispo chez M2D SHOP
@+ _________________ BCM63
SWORKZ - DONUTS RACING - LABEMAX - SRT -
TPRO - PLP -
luc11 Découverte
![](modules/Forums/images/avatars/Perso/denis_img-1155534f8l0.png)
Posté le: 23.07.2011, 19:17:45 Sujet du message: |
testé et approuvé sur le meme chassis et le meme fournisseur ![OK!](modules/Forums/images/smiles/ok.gif) |
juliien71 Ligue
![](modules/Forums/images/avatars/Perso/FranckyGoes_logo_mugen2008.gif)
Posté le: 23.07.2011, 19:56:34 Sujet du message: |
cela apporte quoi ![Question](modules/Forums/images/smiles/icon_question.gif) |
Micland16 Modérateur Elite
![](https://www.monstertruck-team16.fr/media/kunena/avatars/resized/size144/nophoto.jpg)
Inscrit le: 15/01/2007 Messages: 2182 Localisation: Ligue 16 Nouvelle Aquitaine Nord
Posté le: 23.07.2011, 20:39:54 Sujet du message: |
Alu contre Alu je ne suis pas fan, la corps d'amortisseur ne risque pas de s'user tres rapidement
De plus pour sortir, l'huile doit pousser le joint torique, donc il n'est pas là pour proteger le corps de l'amortisseur, mais seulement là pour jouer le rôle d'une valve. _________________ Michaël LANDREVIE |
smagrad Expert*
Posté le: 23.07.2011, 21:17:41 Sujet du message: |
le joint est toujours debordant du piston donc l'alu du piston n'est jamais en contact direct avec le corp. _________________ BCM63
TPRO - PLP -
Miguel374 Elite
![](modules/Forums/images/avatars/gallery/092.gif)
Inscrit le: 09/11/2004 Messages: 1018 Localisation: de retour au coté des bouzes de vaches.
Posté le: 24.07.2011, 07:51:24 Sujet du message: |
perso je les trouve pas sur le site m2d... |
B12 Elite
![](https://img377.imageshack.us/img377/5347/sanstitreyn1.png)
Posté le: 24.07.2011, 09:07:15 Sujet du message: |
pareil pas trouver sur le site ! un petit lien peu étre ? _________________ freiner ???? je suis pas venus la pour freiner !!! |
Posté le: 24.07.2011, 09:44:22 Sujet du message: |
Si le joint est débordant et donc en appuis sur le corps de l'amortisseur, je ne vois pas comment l'huile passant par ces gros trous peut pousser le joint et passer de l'autre coté.
Pour moi l'effet clapet de ces pistons est tres tres limité et ne doit pas être violant. _________________ Michaël LANDREVIE |
laurent Elite
![](modules/Forums/images/avatars/0053.gif)
Posté le: 24.07.2011, 10:59:52 Sujet du message: |
Parce qu'il y un jeux entre le joint et le corps.
J'avais testé ceux pour le mbx5 à l'époque et j'avais senti aucune différence. Par contre, çà se dégradait vite. |
tit-cricri Expert*
![](https://img835.imageshack.us/img835/394/z01bwallpaper12801.jpg)
Posté le: 24.07.2011, 11:24:38 Sujet du message: |
J'ai autre moyen de faire des clapets maison, pour 0 euro. Tu prends une feuille plastique rigide et tu te le découpe de manière à la passer entre la rondelle et le piston. Tu faits le nombres de languettes voulu pour boucher le nombre trous du piston désiré. De cette manière, les languettes vont se tordre en compression et laisser passer le fluide alors qu'elles vont boucher les trous en détente. C'est fait en 5min.
A essayer |
Sylveris Elite
![](https://sylveris.free.fr/logorcmag.png)
Posté le: 24.07.2011, 15:52:13 Sujet du message: |
Micland16 a écrit: | Si le joint est débordant et donc en appuis sur le corps de l'amortisseur, je ne vois pas comment l'huile passant par ces gros trous peut pousser le joint et passer de l'autre coté.
Pour moi l'effet clapet de ces pistons est tres tres limité et ne doit pas être violant. |
Salut à toi,
Le joint est dans une gorge dans la bordure du piston, il ne bouge pas, il sert comme d'un segment sur un piston de mob, pour assurer l'étanchéité. Justement il sert à ce que le piston alu ne frotte pas directement sur le corps. L'huile elle, passe par les trous comme normal, sauf que les trous n'ont pas la même configuration sur le dessus, que sur le dessous du piston, l'effet à la compression et à la détente seront donc différents par rapport à un piston classique. A la détente, l'huile passe par des trous dans le dessous du piston, qui communiquent avec la gorge du joint, le comprimant ainsi contre le corps, lors de la descente du piston. Après pour la réelle différence constatée, il faut essayer...
www.sylveris-rc.fr
smagrad Expert*
Posté le: 24.07.2011, 16:42:02 Sujet du message: |
a la compression
l'huile passe par les 6 trous de 1.4 et autour du piston si la vitesse de deplacement du piston (donc pression au dessus de celui ci)est assez forte
a la detente
l'huile ne peut passer que par les 6 trous de 1.4 car l'augmentation de la pression en dessous du piston fait plaquer le joint sur le corp et rend le tour du piston etanche avec le corp
le but est je pense d'avoir une vitesse de deplacement du piston differente dans les deux phases
apres je pense qu'il faudrait aussi essayer dans certaines configs de pistes de tourner le piston dans le corps.
a essayer.... _________________ BCM63
TPRO - PLP -
Sylveris Elite
Posté le: 24.07.2011, 17:29:16 Sujet du message: |
Merci Sylveris, ton explication est tip-top.
C'est quand même compliqué à mon avis à trouver le réglage qui convient car l'étanchéité donc l'effet doit aussi dépendre de la vitesse de déplacement du piston.
Je vais donc rester sur mes clapets maison. _________________ Michaël LANDREVIE |
B12 Elite
Posté le: 24.07.2011, 17:39:09 Sujet du message: |
quoiquil en soit j'ai toujours pas trouver ces pistons sur le sites en question _________________ freiner ???? je suis pas venus la pour freiner !!! |
smagrad Expert*
Posté le: 24.07.2011, 19:27:03 Sujet du message: |
au risque de vous contredire,
si aucune force ne contraint le joint plaqué contre le corp rien n'assure l'etancheité .
les trous corespondant avec la gorge du joint se trouvent sur le dessous du piston la face du dessus n'a elle que 6 trous "normaux" .
je viens de mesurer je diametre exterieur de ce jeu de piston qui est avec le joint de 14.90 .
si on voulais qu'il soit etanche en permanence je pense que son diametre au repos devrait etre tres legerement superieur au diametre du corp donc 15 .
ce n'est qu un avis peut etre pas top mais je pense viable avec les lois de l'hydraulique. _________________ BCM63
TPRO - PLP -
amontintin Champion du monde
Inscrit le: 02/11/2005 Messages: 6878 Localisation: Beaufort en vallée
Posté le: 24.07.2011, 20:16:03 Sujet du message: |
smagrad a écrit: | au risque de vous contredire,
ce n'est qu un avis peut etre pas top mais je pense viable avec les lois de l'hydraulique. |
teuhteuh, ton psiton est tuojours un poil plus petit que le corp, sinon ton piston ne pourrait pas coulisser dans celui-ci ![Laughing](modules/Forums/images/smiles/icon_lol.gif) _________________ amontintin lecerveaulent.........très lent, mais a quand même trouvé un sponsors.....mdr
fabrice19 Expert*
![](modules/Forums/images/avatars/gallery/1120.gif)
Posté le: 24.07.2011, 20:45:07 Sujet du message: |
Salut tout le monde !! Moi j'aime bien leur principe de fonctionnement mais bon comme tous ils ne sont pas parfait non plus ...
A commencer par leur sens de montage... cela doit fonctionner à l'arrière des durango car les portes a faux sont différents des buggys " classiques" ... mais je les monterai quand même à l'envers sur les 4 amortos de mon buggy...
Ensuite pour ce qui est des diamètres il y quand même deux ou trois choses à respecter sur nos buggy... la première c'est que le diamètre du piston avec le joint ne peut pas être supérieur à celui du corps même en utlisant un matériaux "souple" ! Cela revient à mettre en contrainte l'amortisseur, alors oui cela fonctionne très bien à l'échelle 1 (vtt, moto...) ! mais de quelle sensibilité ont ils besoin ? on ne parle pas du poids non plus
Et si le diam avec le joint fait 15.10 cela veut dire qu'avec la quantité de chocs à encaisser l'amortissement va varié très vite à cause de plusieurs facteurs :
- l'usure du joint qui va le rendre de moins en moins "étanche"
- l'échauffement de tout le système a cause des frottements
voilà pourquoi le diam est plus faible, après pour la valeur cela dépend des marques mais entre 1 et 2/10e on peut dire que cela reste acceptable !
C'est ce 1/10e qui permet suivant le sens de montage d'avoir la détente ou la compression ralentie, dû à l'écartement du joint contre le corps ce qui est simpa c'est que suivant la force de l'impact cela plaque plus ou moins vite et plus ou moins fort le joint contre le corps !! Ce qui en soit est une alternative franchement simpa à ce qui est visible ou non sur les courses
Parlont un peu des défauts
- le premier selon moi l'usure du joint pendant la course !! Faire 45 min de finale doit quand même pas mal secouer tout ça
- avoir une usure symétrique sur les amortos ... entre la gauche et la droite et l'avant et l'arrière !! cela rajoute une combinaison de problèmes potentiels encore plus grande que d'habitude !!
- le désastre qu'il peut arriver si ce système est monté puis négligé !! Car si le guidage de la tige n'est pas parfait, le joint va se déterioré beaucoup plus vite !! ce qui peut entrainer le piston a froter sur l'intérieur du corps... Et la salade d'alu dans l'amorto !!
Voilà ce n'est que mon avis mais !! je pense que ce système mérite d'être tester mais il faut prendre un max de précautions pendant le montage et à l'usage !! Mais cela ouvre pas mal de solutions techniques pour avoir des amortisseurs variables pour ceux qui ont un peu d'imagination de que cela interresse !!
Bye et bonne soirée !! Fabrice VERGNOLLE _________________ Qui sait ce que le 4x2 me réserve !!!
Merci à tous ceux qui m'aident à savoir :
J.C.A. - Cars-distribution - Top Options - VRS Shocks - CHACHAdhésif |
Sylveris Elite
Posté le: 25.07.2011, 00:47:44 Sujet du message: |
amontintin a écrit: | smagrad a écrit: | au risque de vous contredire,
teuhteuh, ton piston est toujours un poil plus petit que le corps, sinon ton piston ne pourrait pas coulisser dans celui-ci ![Laughing](modules/Forums/images/smiles/icon_lol.gif) |
Je pense qu'il parlait du diamètre extérieur du joint, et c'est vrai qu'il pourrait être légèrement plus grand, comme ceux que l'on met entre les corps d'amortos et les tiges, ça n'a rien de stupide. Par contre à 14,90, avec de l'huile tu peux être sûr qu'il gonfle un peu et qu'il fait son étanchéité ! A moins qu'avec les amortos Durango il y ait un petit jeu de plus...dans tous les cas je me méfie de Fioroni, car malgré toutes les nouvelles belles pièces que l'on voit toujours en photo sur leur site, j'en ai vu de près pour lesquelles la finition n'y était pas.
www.sylveris-rc.fr
smagrad Expert*
Posté le: 25.07.2011, 16:46:36 Sujet du message: |
14.90 est le diam avec joint et "gonflé par l'huile " puisqu'ils ont deja tournés
enfin ...
la finition des pistons que j'ai eu etait bien .
rien a signaler de ce coté la
bye _________________ BCM63
TPRO - PLP -
B12 Elite
Posté le: 25.07.2011, 16:47:14 Sujet du message: |
et y a toujours personne qui va dire ou on peu en trouver ?! _________________ freiner ???? je suis pas venus la pour freiner !!! |
fabrice19 Expert*
Posté le: 25.07.2011, 17:23:06 Sujet du message: |
J'ai moi aussi chercher sur le site de fioroni et rien trouvé B12 ... tant pis un coup de tour et pis tout sera ok avec les bon diamètres ![Laughing](modules/Forums/images/smiles/icon_lol.gif) _________________ Qui sait ce que le 4x2 me réserve !!!
B12 Elite
Posté le: 25.07.2011, 17:25:19 Sujet du message: |
non mais je comprend pas y a quelque qu'un qui dis quil sont dispo chez M2D shop et j'ai rien trouver et y a personne pour ecalirer ma lanterne on dirait , vous voulez garder ces piston pour vous tous seul les mecs ? _________________ freiner ???? je suis pas venus la pour freiner !!! |
Darkmo2 Elite
![](modules/Forums/images/avatars/Perso/Darkmo2_lapinmalin1.png)
Posté le: 25.07.2011, 17:30:48 Sujet du message: |
sur le site fioroni :
http://www.fioroni.com/inglese/homepage.asp
sur le site M2D, me semble que les produits plus en stock n'apparaissent plus sur le site (à confirmer...) _________________ losi 8ight E 2.0 EU NEU US 1515 1Y
MP9 TKI3 falcon OS B-Power
DEX410 tekin
Tamiya Egress 2013 |
Posté le: 25.07.2011, 17:35:52 Sujet du message: |
Y'a plus simple quand même ... ![Laughing](modules/Forums/images/smiles/icon_lol.gif) |
turboman Elite
![](https://nsa40.casimages.com/img/2021/03/26/mini_210326103116264348.jpg)
Posté le: 25.07.2011, 18:55:23 Sujet du message: |
YankeeForever a écrit: | Y'a plus simple quand même ... ![Laughing](modules/Forums/images/smiles/icon_lol.gif) |
andremadracing Ligue
![](modules/Forums/images/avatars/Perso/Atox_cavt45f6c3c646232.gif)
Posté le: 25.07.2011, 19:09:41 Sujet du message: |
Particulier ce fonctionnel !!
Nos amortisseurs ont des pistons ayant un jeu périphérique d'environs ( 5/100 sur le diamètre) ce n'est pas un hasard.
Les pistons sont conçus avec des matières ayant un très faibles coef de frottement, il y a bien une raison!
Mais pourquoi pas, il y en a au moins pour tous les gouts!! |
lescargot Découverte
![](modules/Forums/images/avatars/gallery/_orion.jpg)
Posté le: 25.07.2011, 19:17:36 Sujet du message: Amortisseurs |
En étanchéité on peut largement faire mieux que de simple joint toriques aussi..... ![Very Happy](modules/Forums/images/smiles/icon_biggrin.gif) |
B12 Elite
Posté le: 25.07.2011, 19:20:38 Sujet du message: |
j'ai l'impression quil y a bcp de gars qui savent faire mieu mais qui ne disent rien , info ou intox ? c'est mignon mais moi aussi je peu pisser dans la mer pour essayer de la faire deborder ![OK!](modules/Forums/images/smiles/ok.gif) _________________ freiner ???? je suis pas venus la pour freiner !!! |
