The XXX-SCT is a ROAR legal, 1/10-scale SCT based off of a race proven platform that will provide racers and bashers alike realistic looking Sean Geiser ReadyLift licensed body as well as performance driven components in a RTR or BND configuration.
The 1/10 ReadyLift XXX SCT RTR comes ready to run and ready for action. It has a 2WD, ROAR-legal short course chassis, aluminum oil-filled shocks and a LiPo compatible ESC. This 1/10 truck also features a Losi radio system with 2.4GHz DSM technology, a Sean Geiser ReadyLift licensed body with sponsor decals, and generous ground clearance. The XXX-SCT will be comfortable as a basher with plenty of power and designed for durability in the backyard as well as right at home on the track living up to its XXX-platform heritage.
Features
* Durable, composite-molded, race-proven XXX chassis
* LiPo compatible (2S cutoff), water resistant ESC
* LM-32K motor for high speed SCT action
* Spektrum SR300 2.4GHz DSM Receiver
* Aluminum, adjustable oil-filled, coil-over shocks
* Proven 3-gear transmission with a rugged differential
* Adjustable slipper clutch
* Losi digital steering servo
* Realistic short course bumper with mud flaps on the rear
* Short course style tire with Losi exclusive Eclipse tread pattern
* Beadlock-style SCT wheels with color trim rings
* Compatible with a long line of XXX parts currently in hobby shops
Product Specifications
Type:2WD SCT
Scale:1/10
Length:19.69 in (550mm)
Width:11.42 in (290mm)
Height:7.48 in (190mm)
Wheelbase:13.23 in (336mm)
Weight:4.7 lb (2.04 kg)
Tire Type:All-terrain SCT
Motor or Engine:Losi LM-32K performance motor
Speed Control:LiPo-compatible ESC
Radio:Spektrum 2.4GHz DSM
Shock Type:Coil-over, oil-filled
Body:Custom SCT Sean Geiser
Ball Bearings:Complete
Il est vrai que le strike n'était pas une réussite. Ceci dit un gars au club en possède un et il dépose presque sur place nos SC10. Enfin le gars en question a de bons doigts
Un triple X, c'est une voiture de course, en kit, sur le Strike, Losi avait un peu inové avec le moteur central, là, ils reprennent une implantation classique, et pi, y a pas marqué "GRAPHITE" sur les pièces
Cette mode des rtr et chez Losi, des Bind, j'aime pas trop, c'est spécifique au marché US, et à Horizon Hobby, comme le SCT.
Le plus performant à venir, le SC-X60 _________________ Papy boomer
Elle est pas belle la vie.
