philippe27 Champion du monde
Posté le: 30.08.2009, 10:50:11 Sujet du message: Servos mega puissant Hitec HS-7950TH |
The "Ultra Torque" HS-7950TH is designed to operate on a two cell LiPo Pack. Featuring our high resolution "G2" second generation programmable digital circuit and our indestructible Titanium gears, The HS-7950TH has the performance and durability you’ve come to expect from a Hitec servo. Other features in the HS-7050TH include a 7.4v optimized coreless motor, integrated heat sink case, and a top case with two hardened steel gear pins supported by axial brass bushing. The HS-7950TH has been designed for the most demanding hobby applications including the largest aircraft and monster trucks. Featuring a titanic 403oz./in. of torque at 6.0 volts, while still maintaining a respectable 0.15 second transit time.
* G2 Digital Circuit
* Titanium Gear Train (MK first gear)
* Ultra Performance Coreless Motor
* Heatsink Case
* ( O-Rings for Water/Dust/Fuel protection
* Dual Ball Bearing Supported Output Shaft
* Programmable Features Include:
* Dead Band Width
* Direction of Rotation
* Speed of Rotation (slower)
* End Points
* Neutral Points
* Fail Safe On/Off
* Fail Safe Point
* Resolution* (default is high resolution)
* Overload Protection* (default is off)
* Size Category: Standard
* Type: Digital
* Application: Larger Air and Surface products
* Torque: 403 oz/in @ 6V, 486 oz/in @ 7.4V
* Speed: 0.19/0.15 sec @ 60 deg. (4.8v/6v)
* Weight: 2.34oz (66 g)
* Bushing Or Bearing: Bearing
* Bearing: Dual
* Motor Type: Coreless
* Gear Type: Metal
* Gear Material: Titanium
gexgael Découverte
Inscrit le: 27/06/2009 Messages: 70 Localisation: Carcassonne (11)
Posté le: 30.08.2009, 11:23:59 Sujet du message: |
C'est bien beau le copier/coller, tu veux pas traduire ? |
PapyDodu Champion du monde
Posté le: 04.09.2009, 21:43:00 Sujet du message: |
lundi je voi avec mrc si il en on en stock jen fait rentré . |
titis14 Champion du monde
Posté le: 04.09.2009, 21:44:24 Sujet du message: |
Et les recepteurs ils encaisse les 7.4v ? comme un Spektrum par exemple. _________________ Séb-r
www.rcpirate.fr
Xray GTX8 + Reds GT5
Posté le: 04.09.2009, 21:48:49 Sujet du message: |
je me renseigne lundi au prét de futaba mes il me semble que oui pour les 2.4 futaba |
amontintin Champion du monde
Posté le: 04.09.2009, 22:04:55 Sujet du message: |
autre question, les puces perso acceptent -elles aussi le 7.4v ??????car dans le cas contraire faudrat un ptit régu rien que pour elle _________________ amontintin lecerveaulent.........très lent, mais a quand même trouvé un sponsors.....mdr
Posté le: 04.09.2009, 22:47:54 Sujet du message: |
Oui ca reviendrais au même dans ce cas les servo 7.4v ne doivent pas changer grand chose, l'avantage de c'est servo c'est pouvoir avoir un lipo et sans régulateur.
Les servos de 7.4v sont plus puissant peut être mais de nos jours nos servos actuel sont vraiment bien en 6v. _________________ Séb-r
www.rcpirate.fr
