Posté le: 30.08.2009, 10:39:52 Sujet du message: New Harm Large Scale BX 3 Off Road
The BX-3 is a complete new construction especially developed for competition. The chassis offers a lot of features and adjustment possibilities without neglecting service maintenance. HARM Racing is known for extraordinary quality therefore the use of high quality aluminium is standard in the meantime.
The chassis with the equipment “Champion-Edition” has been designed in two pieces as high quality aluminium cannot be bended but the front axle needs to bended in order to guarantee best jump characteristics. This is also a considerable advantage with regard to maintenance as it facilitates quick dismantling of the complete front axle from the chassis. Requirements of different race tracks have been considered also. Weight distribution can be changed quickly by shifting the RC plate including fuel tank forward. It is also possible to mount the engine in lying position. For this change another engine mount is necessary and shorter linkages as well as another pipe have to be mounted. Thus the BX-3 can be perfectly adjusted also on race tracks with artificial turf.
Further highlight are the large-volume and long dampers with a new system for filling. They facilitate huge spring deflection. The BX-3 will be available in two versions. The pictures show the prototype with the equipment “Champion-Edition”. Delivery of the BX-3 will start end of September 2009.
belle mais tres classique
elles se ressemblent beaucoup, faudrait un "vrai" 4x2 avec les réglages utiles comme la chasse ( avec une bonne amplitude ) et le réglage de pincement arriere, anti cabrage .... plus de possibilité pour l'ancrage des amortisseurs ... _________________ rcmag.com pour le forum, les photos et vidéos
