Posté le: 31.07.2009, 07:24:13 Sujet du message: Pneus buggy Losi en gomme "green", soft !
Après son succès aux ROAR Nat's 09, Team Losi propose sa gamme de pneus buggy en gomme "green", soft, qui correspondrait à la M3 Pro-Line, pour les Eclipse, Reptile, XBT, King-Pin, Sted Pin et Taper Pin:
=> Team Losi.com _________________ Papy boomer
"Losi have gone all Green today with the release of their new softest tyre compound; called (if you didn't quite catch it...) Green! Losi's green compound is the softest compound available from Losi, and provides provides increased traction and consistency. Comparable to M3 compound, it should be used when maximum grip is required. Losi's six tyre treads will be available in Green compound between mid-August to mid-September."
