RCmag :: Voir le sujet - Options UltimateRacing du RC8 de Robert Battle!
MessagePosté le: 11.07.2009, 08:56:05    Sujet du message: Options UltimateRacing du RC8 de Robert Battle! Répondre en citant
Utilisées à l'Euro Wink
Chassis ralongé:
Supports amortisseurs ar et av:
Ressorts d'amortisseurs:
Entrée de diff:
Rotules d'amortisseurs:
Renfort de bras sup:
Volant et cloche spécifique RC8:
tit-cricri
MessagePosté le: 11.07.2009, 20:49:43    Sujet du message: Répondre en citant
Quelqu'un sait si le chassi est commmercialisé ? (il me reste 1 mm sous les cellules Mad Laughing )
tit-cricri
MessagePosté le: 12.07.2009, 12:27:35    Sujet du message: Répondre en citant
"UR driver Robert Batlle has been using some parts on his AE RC8B designed and produced by Ultimate Racing during the Euros that helps him to be the first Team Associated driver.
Chasis: ( plus long de 4mm )
Made of 7076-T6 aluminum
Longer than the original one.
Wheight balanced
More stable and easy to drive.
Shock towers:
Diferent positions to improve shock absorber performance.
Schock springs:
Made of the same steel than the 3 times Euros champion shock springs.
Longer than the original ones.
Aluminium gear box input cup.
New long life aluminium gear box input cup to adapt the CVD bone to the new chasis lenght.
Schock standoff.
Made of hard aluminium
Bigger base to avoid bending
Longer to improve shock absorber position.
Ball join gasket to protect the rod ends.
Compack clutch V2
Flywheel adapted to the RC8
For the track conditions is using an standard B10 with one spring of 0.9mm (2 x 1.0mm and 1 x 0.9mm)."
Source : http://www.ultimateracing.es
