RCmag :: Voir le sujet - Fiabilite des servos "savox" ???
philippe27
MessagePosté le: 13.06.2009, 11:07:41    Sujet du message: Fiabilite des servos "savox" ??? Répondre en citant
avez vous une idée de la fiabilite de ces servos
Le SC-1256TG.....20kg-cm pour 0.15 sec/60 ° @ 6.0Volt
le SC-1257TG .... 10kg cmpour 0.07 sec/60 ° @ 6.0Volt
juste ce qu il faut pour le gaz/frein et la direction!
Citation:
"The Savöx SC-125xTG servos series are extremely powerful, fast and equipped with
precise cut gears of a titanium alloy. The SC-1256TG model is extremely powerful
with 20kg-cm Torque at 0.15 sec/60 ° @ 6.0Volt and the SC-1257TG is extremely
quick with 0.07 sec/60 ° with 10kg cm torque @ 6.0Volt. The Savöx servo’s are
equipped with a newly developed 12 bits microprocessor which processes the
signal impulses even faster and more accurate.
The nice gold/yellow
anodized aluminum housing design not only exudes an exquisite style but helps
the operating to stay cool and smooth. The servo’s from the Savöx SC-125x series
are extremely light, they weigh about 20% less than the other servo’s in the
field.
All servo’s from the SC-125x series are equipped with a precision coreless motor
which has brought the output performance to the top level smoother, faster and
more efficient. Super strong and precise-made Titanium metal gear form as the
solid framework of the Savöx servos. The design will make “crumbled gears”
history. Totally Green from material to production, Savöx servos are
environmentally friendly.
The Savöx SC-125x servo’s are ideal for the
serious 1:10 Touring Car, Buggy 1:8, Truggy, Monster Truck and Crawler owner who
knows how to appreciate the added speed, strength and durability of a sublime
servo.
Quality Savox Servos
Savoxtech, a professional and enthusiastic manufacturer of radio control key components.
We design, develop and manufacture our products by ourselves.
Our profession and experienced R&D team is striving for developing superb performance,
most reliable and most compatible products that offers ultimate fun and best value to end users.
Innovative technology and reliable quality is the heart of Savoxtech. With rigid commitment to
innovation and quality, Savox has launched first-in-the-world 12bits 4096 resolution digital servo
comprising coreless motor and Titanium alloy gears in November 2007.
At Savoxtech, each single product is checked and tested through a series of strict and accurate
QC(Quality Control) process by leading edge facilities and trained engineers
Caractéristique:
SC-1258 TG
0.08 sec/60°
12.0 kg-cm
Conditionné dans une petite boite en plastique, comprenant:
- servo
- 4 palonniers
- kit visserie
Bonne finition, palonnier solide, simple a monter (comme tous les servos)
Montage ok, donc je test !
Seul point négatif: bruyant ! quand il est au neutre il "grésille" et donc fait du bruit !
Test a l'arret, rapide, largement assez coupleux pour mon Truggy.
Test en roulage, ben toujours aussi bon, rapidité au rendez vous, réponds tres bien et toujours autant de couple !
Conclusion:
+ : rapide, coupleux, pas cher !
- : bruyant
Pour le peu que j'ai roulé avec, il est tres bon ! pas trop cher, je dirais mieux que les Ace niveau rapport qualité/prix. a vous de tester !
http://savoxtech.com.tw/brush.htm
philippe27
MessagePosté le: 13.06.2009, 16:39:19    Sujet du message: Répondre en citant
http://www.savoxservos.nl/?page_id=496
Le servo Savöx de la série SC-125x sont extrêmement puissant, rapide et équipé d'une coupe précise tandwielset d'un alliage de titane.
Extrêmement puissant à 20 kg-cm à 0,15 couple sec/60 ° @ 6.0Volt (SC-1256)
Extrêmement rapide à 0,07 sec/60 ° à 10 kg-cm torque@6.0Volt (SC-1257)
Le nouveau super-high 12 bits (4096 pas) les processus de résolution microprocesseur le signal d'impulsion encore plus rapide et plus précis.
Le bel or jaune en aluminium anodisé maison est de supprimer la chaleur, assure que le moteur est refroidi et empêche ainsi la réduction de la performance.
Le servo Savöx de la série SC-125x sont extrêmement légers, ils pèsent environ 20% moins d'énergie que les concurrents.
Tous les servocommandes de la SC-125x série sont équipés d'un moteur de base de précision beaucoup moins d'énergie et peut rendre très lisse, efficace et rapide réponse.
Le Savöx SC-125x servo série sont équipés d'un joint torique contre la pénétration de poussière et l'humidité.
Le Savöx SC-125x servo sont idéales pour les graves Touring Car 1:10, 1:8 Buggy, Truggy, Monster Truck chenilles propriétaire et que la valeur de la vitesse, la force et la durabilité d'une sublime servo sait apprécier.
a 1 er vue la tete sur ces servos sont plus haut que d'autres cela peut - /- gêner suivant les châssis
Par contre je ne vois pas de joints d'étanchéité au niveau du boitier ???
http://www.savoxtech.com.tw/images/catalogue.pdf
MessagePosté le: 13.06.2009, 16:45:37    Sujet du message: Répondre en citant
Smile
https://www.rcmag.com/modules.php?name=Forums&file=viewtopic&t=20846&highlight=sav%F6x
Ce sont les mêmes que les Orion, c'est Savöx qui soustraite Wink
philippe27
MessagePosté le: 13.06.2009, 17:01:04    Sujet du message: Répondre en citant
papymini tu en penses quoi sur la qualité de ces servos
techniquement ils ont l'aire très performant mais en fiabilité ???
MessagePosté le: 13.06.2009, 17:09:29    Sujet du message: Répondre en citant
De ce que j'ai pu en lire, aucun souci, pour Savöx comme pour Orion Wink
C'est certain qu'il y a quelque cas d'espèce Mad
Pour le prix, Savöx a l'air moins cher, il faut fouiller Cool
La gamme Savöx est plus complète, avec un "Low Profil" entre autre, mais il devrait apparaitre chez Orion, vu, quelque part Wink
philippe27
MessagePosté le: 13.06.2009, 21:53:12    Sujet du message: Répondre en citant
pouvez vous me confirmer de l'etancheité ou pas de ces boitiers de ces servos et d'avoir l'avis d'utilisateurs en TT et/ou Truggy
philippe27
MessagePosté le: 15.06.2009, 12:46:12    Sujet du message: Répondre en citant
a 1er vue peut de Ttiste utilisent cette marque de servo ???
Max_Speed
MessagePosté le: 15.06.2009, 12:52:42    Sujet du message: Répondre en citant
Faut dire que ces servos ne sont apparus que l'an dernier (et encore, je ne me souviens pas qu'ils aient été chez les magasins étrangers les plus connus), et en France depuis quoi ... Un mois ou deux ?
C'est pas un peu tôt pour avoir un retour sur leur fiabilité ?
Ça passait ... C'était beau ...
Lonestar
MessagePosté le: 15.06.2009, 13:05:33    Sujet du message: Répondre en citant
ils ont bonne reputation en helico, a voir s'ils sont capables de nous faire des servos qui tiennent les contraintes rencontrees sur nos vehicules... pas qu'elles soient moindres, mais elles sont "differentes". Effectivement, un an, c'est un peu rapide pour juger de la fiabilite a moyen/long terme.
le rapport perf/prix est en tout cas bien allechant. Mais chez Orion, ils doivent quand meme l'avoir un peu mauvaise Mad
Paul
philippe27
MessagePosté le: 04.07.2009, 09:16:12    Sujet du message: Répondre en citant
Svp et merci d'avance
savez vous si il y a des joints d'étanchéité entre le boitier et des les extrémités sur ces servos
fc33290
MessagePosté le: 04.07.2009, 11:42:47    Sujet du message: Répondre en citant
au bout de 3 courses je m'apercois qu'ils prennent beaucoup de jeux !!!!! fonctionnel !!!! pas top mais restent de bon servos pour le prix
AGAMA pack FR, BULLIT B-218,ligne OS 2060, BETA, FUTABA,
http://ttrc33.forumsactifs.com/portal.htm
http://www.ttrc33.fr/Bienvenue_au_TTRC33.html
