RCmag :: Voir le sujet - Un outillage utile pour les trous de piston amorto
philippe27
MessagePosté le: 19.06.2019, 16:09:29    Sujet du message: Un outillage utile pour les trous de piston amorto Répondre en citant
Product Overview
The Avid piston drill set includes twist drill bits between 1.1 - 2.0mm in increments of 0.1mm. Comes with a handy drill bit holder so you can easily drill your custom pistons with your hand. We then topped it off with a convenient box that has a color-coordinated label so you can quickly figure out the drill bit size if they get out of order.
Specifications
Twist drill bits between 1.1 - 2.0mm in increments of 0.1mm.
Includes a drill bit holder.
Comes in a convenient box with a color-coordinated label for the drill bit sizes.
https://www.avidrc.com/product/5/accessories/3049/Piston-Drill-Set-11-20mm--AV10014-accessories.html
philippe27
MessagePosté le: 19.06.2019, 16:10:10    Sujet du message: Répondre en citant
https://www.avidrc.com/search/?x=22&y=16&s=+AVID+piston+drill+set
