Italian brand Pirani RC introduce a totally new tool, ROLLER.
Roller is a high precision tool, using the simply system of a air ball. The tool is suitable for all kind of screwdrivers and help you to make a better adjustment of toe and camber angle.
It's very small, just 2cm diameter, you can put it in your pocket, and use as soon as you need.
Roller is a new kind of tool, no other professional tool's factories ever produce this kind of object.
