Posté le: 02.05.2013, 14:59:57 Sujet du message: New Tekin RX8 Gen2
Nouvelle version du RX8
Citation:
We took the best and just made it better! The RX8 GEN2 is ready to tear up the track with new features and stylish new looks. Packing a High Voltage Programmable BEC, EZ Access HotWire port, Datalogging capablilites and smoother throttle and braking profiles, the RX8 GEN2 is sure to impress. Get ready for the next generation in intelligent, high performance racing equipment. We raised the bar; time to step up!
Ultra-smooth and Precise Throttle and Braking Control
Compatible with Sensored/Sensorless Brushless and Brushed Motors
Easily Access Programming, Anywhere, Anytime
Datalogging Capability
EZ Access HotWire Programming Port
HotWire PC Interface for Advanced Programming and Updating
D2: Dual Drive Mode Technology
On-Board Temperature Indicator
Removable/Replaceable Cooling Fan
HDAC: High Density Copper PCB's
Sensor Plug for Precise Commutation with all Motors
Gold-plated Solder Posts for Easy Wire Replacement
Self Test Diagnostics and Factory Reset
Pit Tune Mode
DGF2: Digital Glitch Filtering V2
QuickTune™ Programming
One-Touch Radio Calibration
30mm RX8 Fan Included #TT3832 >>view image
High airflow volume for extreme cooling
Impact resistant durable design for offroad applications
Brushless Motor
High Voltage BEC (6.0v/7.4v)*
Drag Brake (13 steps)
Brake / Reverse Strength (13 steps)
Current Limiter (none + 12 steps)
Neutral Width (13 steps)
Timing Profiles (5 preset - 2 custom*)
Adjustable Throttle and Brake Minimums
Custom Throttle Curves
Motor/Reverse Type: Brushless, Brushed, No Rev, Rev Delay
Voltage Cutoffs (none, 2S, 3S, 4S, 5S, 6S, Custom)
Save, Load and Share custom ESC setup files*
Save, Load and Share Data Log files*
Extensive Tuning via Tekin HotWire PC Interface
en gros, on peut gerer comme pour le Viper la tension de sortie du BEC ce qui est un progres (et le Tekin sait passer de Dual en Sensorless ce qui n'est pas le cas du Viper aujourd'hui)
EZ hotwire (Easy ???) il faut voir ce que c'est...
en revanche, il manque toujours 2 points :
- des gros condo pour préserver les lipo en cas de forts appels de courant.
- une gestion du timing dynamique des 4 pôles comme on le trouve pour les 2 pôles...
à première vue, ça ne révolutionne pas les ECS 4S-6S _________________ Vive l'électron liiiiiibre !
