Posté le: 17.03.2013, 23:47:23 Sujet du message: News iMax X200 Smart Charger W/ Touch Screen All In One Char
iMax X200 Overview
Imax X200 is a new design from imax company, it's different from all the previous versions, mostly in it's touch screen, and it has a USB Port for charging your smart phones.
Beautiful Touch Screen All-in-One Charger for 7.4V-22.2V Li-Po battery
It's Powerful 10A charge, not bad for a compact size charger.
max X200 Has New Compact balance board design
This kind of chargers used to be awkward and messy, now it's all built in one board.
As you can see, the Imax X200 comes with a Big Colorful Touch Screen
The user interface is a joy to use, very simple and easy to operate.
This is how we use the Imax X200 Charger
You will need a DC12-15V Power Supply (not included).
It has an USB charging port.
iMAX X200 Smart Charger Features :
- 4.3" inch Touch Screen TFT display
- iM.OS system
- 32 bit processor
- Multiple language interface
- IBP adapter board- for Deans, Tamiya, EC3, and other connectors
- USB Port
- Supports 6 different types of battery chemistry
- Up to 6S Lithium
- Max charge rate 10 amps
- DC Power Only
Imax X200 Specifications:
- Touch Screen : 4.3-inch 480 x 272 px
- Operating voltage rang : 11.0-18.0V
- Circuit Power : Max 200W(charging) and Max 20W(discharging)
- Charge current range : 0.1-10A
- Discharge current range : 0.1-3A
- Current drain for balancing LiPo : 300mAh/cell
- Lithium battery cell count : 1-6 series
- NiCd/NiMh battery cell count : 1-16 series
- Pb battery voltage : 2 to 24V
- Dimension : 148 x 140 x 48mm
- Weight : 0.55kg
- System: iM. OS V2.0.8
Imax X200 Package Includes :
1. X200 Charger Body
2. All-in-One Balance Board
3. Red Black wire lead
4. Crocs Clamps
5. Stylus for touch screen (however, you can use finger to touch)
You may want to compare with the other imax chargers .
Add to Cart:
Manufactured by: IMAX
This product was added to our catalog on Saturday 16 February, 2013.
[video=youtube;n5lqp0pHwgk]http://www.youtube.com/watch?v=n5lqp0pHwgk[/video]
[video=youtube;CpS_TcFTycw]http://www.youtube.com/watch?v=CpS_TcFTycw[/video]
