Posté le: 19.06.2019, 16:09:29 Sujet du message: Un outillage utile pour les trous de piston amorto
Product Overview
The Avid piston drill set includes twist drill bits between 1.1 - 2.0mm in increments of 0.1mm. Comes with a handy drill bit holder so you can easily drill your custom pistons with your hand. We then topped it off with a convenient box that has a color-coordinated label so you can quickly figure out the drill bit size if they get out of order.
Specifications
Twist drill bits between 1.1 - 2.0mm in increments of 0.1mm.
Includes a drill bit holder.
Comes in a convenient box with a color-coordinated label for the drill bit sizes.
