Long wheelbase 7075 aluminum chassis
Fine Adjustment Aluminum D-Mount
Revised Rear Upright Geometry
CVA drive shafts included
Universal & CVA compatibility
43/10 diff gear ratio with lightweight gears
Harder suspension arm material
Sintered brake pads & metal rotors
Enclosed radio tray
Aluminum servo saver arm
One-piece lightweight wing mount
Aluminum caster blocks
Aluminum steering blocks
Carbon graphite steering arms
Stand-up servo mounting
Steel turnbuckles
Big bore threaded coilover shocks
Carbon graphite front and rear shock towers
Aluminum arm blocks
Hinge pin inserts
Protective boots on central drivetrain
Threaded outer hinge pins
Sway bars front and rear
Split center bulkhead
Lightweight spur gear
Lightweight diff outdrives and center inputs
Lightweight front aluminum axles
Racing fuel tank with stone filter clunk
Pro-Line Trifecta Lexan rear wing
Pro-Line Enforcer clear buggy body
Source HotBodiesRacing _________________ Papy boomer
Elle est pas belle la vie.
