The XAct 21 Sportive offers a great value engine package, using materials and components that offer an engine that punches far above its price point.
The Sportive .21 uses a 3 port liner to offer high performance and used a high quality 2 needle (+ idle) race carburettor for easy tuning and high performance.
Using industry standard mounting points and SG style crank this is a drop in replacement in pretty much any 1/8th off road vehicle. The turbo head button requires a turbo plug, for ease of tuning we recommend a hot plug is used.
3 Port ABC Piston and Liner for high power output.
Double bushed “PRO” Con Rod.
Turbo head Button
German manufactured O rings for long life.
High quality 2 needle carburettor with thermal heat shield for consistent tuning
Includes 8.00mm carb venturi insert with alternative fitments available.
Black treated crankcase with high quality bearings and laser etched logo.
Multi fin heat sink head for enhanced cooling.
Pre shimmed for 20-25% nitro.
Each engine is hand assembled in Europe and each component is inspected during this process to ensure high quality and long life.
