RCmag :: Voir le sujet - PICCO V1.21 TEAM DLC Ceramic Off-Road
philippe27
MessagePosté le: 28.07.2017, 11:59:05    Sujet du message: PICCO V1.21 TEAM DLC Ceramic Off-Road Répondre en citant
The Picco V1 Team DLC CER is the brand new top performance off road engine in our products line.
5 port hard chromed liner Piston CNC machined from billet 14mm DLC balanced shaft with silicone insert Knife edged lightweight aerodynamic con-rod Low CG cooling head 14mm ceramic Swiss-made main bearing Composite 3-needle slide carburetor Displacement: 3,49cc Bore: 16,03mm Stroke: 17,30mm Output: 2,7hp @ 34,000rpm
http://www.mwrccars.at/default/picco-v1-21-team-dlc-ceramic-off-road.html[/img]
