RCmag :: Voir le sujet - New FX K301 3-port off-road engine
philippe27
MessagePosté le: 28.07.2017, 11:53:22    Sujet du message: New FX K301 3-port off-road engine Répondre en citant
FX 3.5cc Engine .21 - K301 ##650101
New FX K301 engine is an all-new 3-port engine which replaces the #650100 K3 engine. The K301 is based on the K3 engine but incorporates numerous improvements and refinements. With focus on lower fuel consumption, the intake was redesigned and improved. All-new features include: new updated crankcase and backplate, and a new method of laser engraving. The engine includes a ceramic bearing and a diamond-coated crankshaft.
Significant improvements were incorporated in the production & assembly processes, with new and even more precise quality inspection. All parts are individually measured and then specially selected and matched to increase engine reliability, performance, and quality.
All of the finest engineering and craftsmanship has gone into the concept, design, creation, and finishing of FX Engines. This engine and all of its parts were designed and manufactured by FX in-house in Slovakia, Europe from the finest European materials and using the most advanced Swiss, German, and Italian technologies. Even the crankcase was die cast in-house using fully-robotic die-casting technology.
All parts are individually measured and inspected, and all dimensions are recorded to ensure a full manufacturing & assembly record of every single part. Each engine includes a manufacturing certificate that records all important serial numbers and measurements so that, at any time, all details of the production – material batch, machine programs, responsible craftsperson, and production dates – can be traced back to the beginning.
Features:
3-port, high-competition 1/8 off-road engine
14mm high-precision, silicone-filled crankshaft
DLC Diamond-coated crankshaft
CNC-machined silicium piston
Designed and manufactured in Slovakia, Europe
Engine manufacturing certificate included
Specifications:
Displacement: 3.5cc
Bore: 16.40mm
Stroke: 16.40mm
Weight: 349g
Max. power: 2.6 HP @ 34,000 RPM
Practical range: 4,000-42,000 RPM
Ports: 3 transfer ports
Piston: CNC-machined silicium
Sleeve: CNC-machined brass, hard chrome plated
Front ball-bearing: 7x19mm, made in Japan
Rear ball-bearing: 14x25.8mm ceramic, made in Germany
Crankshaft: 14mm
Carburetor: Alloy body with thermal isolation; 3-needle with modular venturi
Glow plug: X3
Exhaust position: Rear
Includes:
X3 glow plug
Exhaust gasket
Cylinder-head shim
Carburetor venturi
3mm dust cap
6mm dust cap
16mm dust cap
18mm dust cap
http://www.fx-engines.com/engines
