Combining the winning design with the manufacturing wizardry of Thunder Tiger, we present to you the RTR high performance 1/8 electric buggy, the Bushmaster 8E. This intricately designed 1:8 brushless electric buggy can propel itself on any race track with ease and the front/rear shock absorbers, a metal reinforced chassis with a low gravity design, 2000KV brushless motor and 3S~4S LiPo battery all complement each other perfectly to give you maximum force and fun. 16mm hi-capacity hydraulic shock absorbers can provide maximum tire traction. The interior electric components and body adjustments are pre-set at the factory, so that you can enjoy the exhiliration of the Bushmaster 8E right from the box. The perfect mix of speed and handling at your fingertips. It'll be your best option on the tracks! Original Video: https://youtu.be/uPj2bVebM0E by Wilimovich
