Posté le: 29.06.2016, 05:43:25 Sujet du message: chargeur EVPEAK CQ3.
Caratteristiche:
- Voltaggio corrente AC: 110-220 V
- Voltaggio corrente DC: 11-18 V
- Potenza Carica: max. 100 W x4
- Potenza Scarica: max. 10 W x4
- Range Corrente di Carica: 0,1-10 A
- Range Corrente di Scarica: 0,1-5 A
- Tolleranza di Bilanciamento: +-0,01 V
- Numero Celle NiCd/NiMh: 1-15 cells
- Numero Celle LiPo/LiLo/LiFe: 1-6 series
- Voltaggio Batterie Pb: 2-24 V
- Digital Power: 3-24 V
Accessori:
- 1x AC Power Cord
- 1x DC Input Cable XT60
- 4x Charging Cable
- 4x Balancing Adapter Board XH
Setup System x modelli 1:10 On-Road V2.0 Yeah Racing
Stampa
Our Setup System has been redesigned to give r/c racers accurate measurements for their 1/10 on road chassis's. We improved the look and made it even more lightweight. This time we incorporated bearings to keep everything smooth so the friction of your setup surface will not prevent the setup system from getting an accurate measurement.
