RCmag :: Voir le sujet - Tamiya 1/14 R/C Team Hahn Racing MAN TGS (TT-01 Type-E)
philippe27
MessagePosté le: 27.01.2016, 20:14:45    Sujet du message: Tamiya 1/14 R/C Team Hahn Racing MAN TGS (TT-01 Type-E) Répondre en citant
The Tamiya radio control replica faithfully captures the giant race truck. The polycarbonate body sits atop the TT-01 E chassis, which is designed for easy assembly and maintenance.
Features:
1/14 scale R/C model assembly kit.
The form of the MAN TGS racing variant is captured accurately by a 4-piece durable and lightweight polycarbonate body.
Included marking stickers recreate the sponsor livery of the #3 Team Hahn Racing truck for the 2016 season.
Newly designed 70mm diameter radial tires and wheels.
Compatible with LEDs and separately-sold Tamiya LED Light Unit.
The TT-01 Type-E chassis features a shaft-driven 4WD system.
A wide range of option parts is available to tune the TT-01 Type-E chassis.
philippe27
MessagePosté le: 27.01.2016, 20:39:51    Sujet du message: Répondre en citant
Tamiya 1/14 R/C Mercedes-Benz Actros 3363 6×4 GigaSpace
Features:
The body of the Actros 3363 is recreated accurately using newly-molded parts differentiating it from the 1851 spec model.
The tried and tested Tamiya 3-axle chassis utilizes a tough ladder frame with aluminum side channels and resin cross members. A realistic drivetrain setup sees the front mounted motor powering twin rear axles.
3-speed transmission can be controlled via 4ch R/C transmitter. Item 7255252 is the perfect radio to compliment the Actros kit.
Metal leaf spring dampers with built-in coil springs provide durable suspension.
Coupler is included to enable connection with any currently available Tamiya 1/14 scale trailers.
Compatible with the tractor truck option parts (TROP) Items 56531, 56532 and 56536. Use with Multi-Function Control Unit MFC-03 (Item 56523) (or MFC-01, Item 56511) for realistic LED lights and sounds.
Specifications: Length: 538mm, Width: 195mm, height: 305mm.
Requires: 4-Channel radio, ESC, TS Paint, 7.2Volt battery and charger.
