RCmag :: Voir le sujet - Moteur BP Racing 535R Tuned
Moteur BP Racing 535R Tuned Aller à la page Précédente  1, 2
philippe27
MessagePosté le: 18.04.2014, 19:37:49    Sujet du message: Répondre en citant
BP Racing X7RB 7 Port .21 Tuned Buggy Engine w/ Boosters
BP Racing X7RB
HP: 2.7
Ports: 7 + 3 (Multi-Port Exhaust)
Stroke: 16.75mm
Bore: 16.3mm
Displacement: 3.49cc
Weight: 330g
RPM: 36000rpm
RPM Range: 5000-42000rpm Crankcase: Black Powdercoated
Crank: Lightened 14mm w/ Bi-Turbo Cuts
Connecting Rod: Knife Edged, 30.5mm for Improved Piston Stability
Piston: CNC Milled, Reversed Dish, Lightened
Sleeve: 7 Port Tuned, Bypass Slots, Multi-Port Exhaust
Bearings: Double Sealed 607ZZ Front Bearing, 14x26mm Rear Bearing
Caburetor: 2-Needle, 9mm Aluminum/Nylon Hybrid Body, 6.5mm Insert
Backplate: CNC Milled, Double O-Ring Sealed
Button/Head: 2-Piece Cooling Head/Button Hybrid, more efficent cooling, increased engine performance stability
Note: Flanged flywheels may not fit over the engine block. BP uses a larger-than-normal diameter around the front bearing. This may require you to utilize a different clutch or flywheel. Alternatively, the flange from your flywheel maybe ground down or removed.
Sold Out
Model: BPRBHX7RB
0 Units in Stock
Manufactured by: BP Racing
Chris21000
MessagePosté le: 17.10.2018, 21:51:19    Sujet du message: Répondre en citant
Bonjour a tous ,
Quelqu'un aurait encore la notice de ce moteur 535 car je viens d acheter une kyosho et j ai deux moteur comme celui ci et j avais besoin des réglages conseillé d usine ?
Merci d avance
