RCmag :: Voir le sujet - SWORKz is the limited edition LPF-7 nitro engine
philippe27
MessagePosté le: 03.04.2018, 17:23:41    Sujet du message: SWORKz is the limited edition LPF-7 nitro engine Répondre en citant
See: SWORKz
Coming soon from SWORKz is the limited edition LPF-7 nitro engine. Based on the sucessful S7 EVO II nitro engine, an O.S. Spec II with a Spec III carburetor, the LPF-7 features a low-profile cooling head with more cooling surface than the standard LPF head. Only 66 LPF-7 nitro engine will be available worldwide in mid-April.
philippe27
MessagePosté le: 05.04.2018, 19:24:26    Sujet du message: Répondre en citant
The SWORKz LPF-7 engine project is specially made for all SWORKz car fans. The limited edition engines comes with special passion red color heat sinks. Limited to just only 66pcs in the world and with different serial numbers. Its special crankcase is made in Japan and has a limited edition logo design. LPF-7 engines have been tested and carefully selected to give maximum performance and run time. This engine uses a 3 port piston sleeve design for better power delivery and lower fuel consumption. The crankshaft of the SWORKz LPF-7 Limited Edition is balanced and DLC coated. You have a choice to choose a lucky number engine for your racing. Features: 1. SWORKz LPF-7 Limited Edition Engine utilizes a 3 port piston sleeve design for better power delivery. 2. The crankshaft of the SWORKz LPF-7 Limited Edition is balanced and DLC coated. 3. The SWORKz LPF-7 Limited Edition engine comes standard with a black coated crankcase and carburetor. 4. The SWORKz LPF-7 Limited Edition engine is installed with a high quality rear ceramic ball bearing. 5. The SWORKz LPF-7 Limited Edition Engine's 3 needle carburetor system is easy to tune and is more efficient than before. 6. The SWORKz LPF-7 Limited Edition Engine's low profile cooling head provides lower CG and better stability for your buggy. 7. The SWORKz LPF-7 Limited Edition Engine's low profile cooling head has its own limited edition number. 8. The SWORKz LPF-7 Limited Edition Engine comes with limited edition logo.
topgeorges
MessagePosté le: 06.04.2018, 07:52:05    Sujet du message: Répondre en citant
tiens un OS Surprised Surprised Surprised
Silverfox
MessagePosté le: 06.04.2018, 08:24:32    Sujet du message: Répondre en citant
Quelqu'un a déjà calculer le nombre de déclinaison sortant de chez O.S. Rolling Eyes
AGAMA N1 NITRO
FX 225 et NOVA B5
SANWA MT 44
SPONSORS: PROMODELISME67
