RCmag :: Voir le sujet - News Equilibreur de Roue TT 1/10 1/8 JConcepts
philippe27
MessagePosté le: 08.03.2018, 15:38:37    Sujet du message: News Equilibreur de Roue TT 1/10 1/8 JConcepts Répondre en citant
http://www.jconcepts.net/garage/projects/tire-balancer
http://blog.jconcepts.net/2018/03/jconcepts-tire-balancer-w-case-black/
The base of the item is built to protect, position and maintain a small footprint at all times. The base has 4 stand-off legs to hold a steady structure while a thumb screw secures the upright in either the up or down position. The JConcepts balancer is pre-assembled and backed by JConcepts customer support and racing team lineage.
Notes – The JConcepts Racing Team uses a modeling clay for balancing material which is readily available through hobby based retailers.
Features:
· JConcepts design, function
· Aluminum and steel construction
· Collapsible, lay-down design
· Center hub assembly with bearings
· Compatible with 1/10th and 1/8th vehicles
· Sturdy base with stand-off legs
· Black anodizing, etched instructions
· Fast, thumb nut and screw assembly
· Pre-assembled
· Includes storage box with foam padding
JConcepts Tire Balancer w/ case – black
Part# 2538-2
UPC Code – 845937019325
http://www.jconcepts.net/shop/tire-balancer
[img][/img]
philippe27
MessagePosté le: 08.03.2018, 15:40:36    Sujet du message: Répondre en citant
ils font meme des brosse a dents !!!!
http://www.jconcepts.net/shop/liquid-application-brush
philippe27
MessagePosté le: 08.03.2018, 15:42:51    Sujet du message: Répondre en citant
Existe en Bleu
