RCmag :: Voir le sujet - News HB Racing Ride Height Gauge
philippe27
MessagePosté le: 24.02.2018, 21:44:53    Sujet du message: News HB Racing Ride Height Gauge Répondre en citant
New from HB Racing is the ride height gauge that has 2 modes to assist in quick and accurate measurement of the ride height of most 1/10 & 1/8 buggies and truggies. The standard mode uses a thumbscrew to lock the height of the tool, then racers adjust the suspension until it matches the tool height. The “Active Measurement Mode” uses the precise weight balance of the measurement arm so that racers can loosen the thumb screw and slide the tool under the car. The measurement arm pivots on dual ball bearings, so it will touch the bottom of the chassis and show the ride height in real time as it is moved under the car. It’s machined from aluminum and hard anodized for durability. Height markings are laser etched on the tool for quick and easy adjustment. The measurement arm can be unscrewed for compact storage.
