Posté le: 17.08.2017, 19:14:44 Sujet du message: X-Act .21 Pro 8 ITALIA Nitro Engine. 8P, Turbo Button by Nov
X-Act .21 Pro 8 ITALIA Nitro Engine. 8P, Turbo Button by Novarossi
NOVAROSSI
Power, ease of tuning and Novarossi quality all at an amazing price point. These Pro8 Italia engines leave nothing to be desired.
Now available from X-Act for 2016 is the all new Pro 8 Italia. By working hand in hand with Novarossi this offers performance previously unseen in the X-Act range. We have specced the best components possible and offer a far better engine we believe than anything else available on the market at this price.
The 8 port piston and liner gives impressive power all the way from bottom end to top end with impressive maximum RPM, allied with a typical Novarossi 24069 carburettor this makes for a very easy to live with powerplant that will work well on a varaiety of tracks.
Great performance in both 1/8 Buggy or Truggy.
8 Port Piston and Liner set (NV-08538A as per Novarossi 421B)
14mm crank shaft
Double bushed light weight Con Rod
High Qauality two needle carb with 8.0mm venturi
Double sealed front bearing - two seals at the front to keep dirt out (NV-07011)
Turbo head button with NV-C6TGC included
Pre shimmed for 25% nitro
