Posté le: 24.07.2017, 18:05:16 Sujet du message: VS Racing B01-DLC Limited Edition .21 engine
Rody Roem’s World Champion Products have introduced the new VS Racing B01-DLC Limited Edition .21 engine. The power plant is limited to 50Pcs world wide and based on the very powerful VSB01. DLC technology is applied on the crankshaft to lower internal friction and increase life of the crankshaft pin, together with some addional ‘Rody’ touch and development, equipped with a VS Spec combustion chamber. The VS Racing B01-DLC Limited Edition is also available in combo including VS EFRA 2135 pipe.
“This engine is developed to find the best balance between performances, relaiability and costs.” – Rody Roem
Features:
Long Stroke 16.8mm
Specific 3 Ports design
CNC machined flat piston
14mm Bi-Turbo crankshaft, balanced, lightened and silicone paste,’Rody’ + DLC treament
Competition Conrod
Turbo combustion chamber VS Spec.
14mm high-speed main bearing
7mm high-speed front bearing with rubber protection
VS Spec. lightweight cooling head
VS Spec. crankcase
VS Spec. aluminum lightweight slide carburettor with double adjustment
6.5mm aluminum restrictor
This engine is developed to find the best balance between performances/relaiability and costs.
