Posté le: 29.02.2016, 16:30:56 Sujet du message: Vous connaissez cette marque de pneus WOW Racing TT 1/8
WOW Racing Wheels and Tires deliver the utmost performance for your machine. Stiffer wheels allow less deflection and withstand higher g-loads and forces providing consistant control. Closed cell foam inserts allows the sidewalls of your tires to retain structural shape and resist deformation under hard cornering or load outs from jumps. A variety of tread patterns and compounds allow you to dial in your machine for maximum traction and control. Rubber compound development from WOW racing includes specific durameter numbers that meet grip requirements for colored compounds. Each tire is computer modeled and tested to ensure the best performance and true roundness to elilminate vibrations and maintain perfect balance.
