RCmag :: Voir le sujet - Pour les passionnés de gros char métal Rc
philippe27
MessagePosté le: 20.02.2015, 12:07:56    Sujet du message: Pour les passionnés de gros char métal Rc Répondre en citant
https://www.youtube.com/watch?v=-OdGh8guiFU#t=236
https://www.youtube.com/watch?v=6vhLVa-gaqM
https://www.youtube.com/watch?v=mMecCLE8oEI
https://www.youtube.com/watch?v=-8Q3V4P6ZxU
http://forum.worldoftanks.com/index.php?/topic/396246-made-in-china-documentary-metal-box-models/
http://hobbyhavoc.com/forum/index.php?topic=1520.0
philippe27
MessagePosté le: 20.02.2015, 12:17:39    Sujet du message: Répondre en citant
http://members.upc.nl/i.cerjak/CT.htm
RC Transmission & Gearbox Plans
[url][/url]
http://members.upc.nl/i.cerjak/index.htm
http://members.upc.nl/i.cerjak/feedback.htm
Product range ( capacity and power power classifications )
CT1, especially designed for tracked vehicles, like large scale model tanks.
It has 2 output shafts, fully controlled by 2 servos. Suitable for tracked vehicles up to 30kg
CT2, makes your RC car or truck go reverse or up to 1.5x as fast, and gives you a controllable clutch.
It’s a universal transmissions with a controllable clutch and 2 selectable speeds, controlled by one servo. Suitable for power levels 500 to 750 Watts (1.0 HP)
CT3, a universal 3-speed transmission, with 3 selective speeds controlled by one servo.
Configurable as a 3-speed gearbox for your car or truck, or as a 2 speed with reverse. The CT3 can be used in combination with the CT1 and CT2. Suitable for power levels 500 to 750 Watts (1.0 HP)
CG, a universal tank gearbox with 2 controllable clutches and build in 3-speed gearbox (reverse, low, high). For use in big scale tracked vehicles.
This classic transmission is used in my first tank projects. Suitable for tracked vehicles up to 30kg.
CG2, a universal tank gearbox with 2 controllable clutches and build in 3-speed gearbox (reverse, low, high). For use in big scale tracked vehicles.
This transmission is a MkII version of the CG. Suitable for tracked vehicles up to 50kg.
CG3, a universal tank gearbox with a double differential steering system, 3 speed forward and 3 speed reverse gearbox. For use in big scale tracked vehicles. Suitable for tracked vehicles up to 150kg.
For more heavy transmissions see this page
All product ‘downloads’
Downloads’ 3D CAD and 2D plans.
By popular demand; transmission plans available in 3D format (step & parasolid)
Please email me your request, specify file&format: for example CT3/step.
You will receive the file asap
All my efforts are for free, donations are very welcome!
CT1
Cerjak Transmission 1, especially designed for tracked vehicles, like large scale model tanks. It has 2 clutched output shafts with independent reversible directions, fully controlled by 2 servos. 3D CAD data and/or 2D production drawings available on request. Suitable for tracked vehicles up to 30kg. More details can be found on this page.
(Click on picture to see larger image)
CT1
CT2
CT2, makes your RC car or truck go reverse or up to 1.5x as fast, and gives you a controllable clutch. It’s a universal transmissions with a controllable clutch and 2 selectable gearings, controlled by one servo. 3D CAD data and/or 2D production drawings available on request. Suitable for power levels 500 to 750 Watts (1.0 HP) More details can be found on this page.
CT2
CT3
CT3, a universal 3-speed transmission, with 3 selectable gearings controlled by one servo. Configurable as a 3-speed gearbox for your car or truck, or as a 2 speed with reverse. The CT3 can be used in combination with the CT1 and CT2. 3D . 3D CAD data and/or 2D production drawings available on request. Suitable for power levels 500 to 750 Watts (1.0 HP) More details can be found on this page.
CT3
CG
Cerjak Gearbox, is an universal tank gearbox with 2 controllable clutched outpit shafts and a build in 3-speed gearbox (reverse, low, high). For use in big scale tracked vehicles. More details can be found on this page.
CG
CG2
CG2, is a ‘MkII’ of the original CG, fully fitted with ball bearings, increased power capability, and improved shifting mechanism. 3D CAD data and/or 2D production drawings available on request. Suitable for tracked vehicles up to 50kg.
CG3
CG3, is a heavy duty differential steering system tank gearbox, with 3-speed forward and reverse. More details can be found on this page. 3D CAD data and/or 2D production drawings available on request. Suitable for tracked vehicles up to 150kg
CTV
Cerjak Transmission Variator, is an universal tank transmision, with 2 servo-controlled variable transmissions, and one servo-controlled forward/backward gearshift. 3D CAD data available on request. Suitable for power level up to 600 Watts (0.8 HP)
CTV
CTV2
CTV2, is an universal tank transmision, with 2 servo-controlled reversible variable transmissions, controlled by 2 servo-motor spindles. 3D CAD data available on request. Suitable for power level up to 600 Watts (0.8 HP)
CTV2
Gatling
Motorized gatling-like blanks firing cannon. 3D CAD data and/or 2D production drawings available on request.
Gatling
philippe27
MessagePosté le: 20.02.2015, 12:19:52    Sujet du message: Répondre en citant
[url][/url]
philippe27
MessagePosté le: 20.02.2015, 12:48:55    Sujet du message: Répondre en citant
philippe27
MessagePosté le: 20.02.2015, 12:53:02    Sujet du message: Répondre en citant
http://members.upc.nl/i.cerjak/Vixen_V8.htm
More videos
http://www.youtube.com/user/V8Vixen1#p/u/1/PjgR2m9XuIs
http://www.youtube.com/user/V8Vixen1#p/u/2/7Zn--wjdnp0
http://www.youtube.com/user/V8Vixen1#p/u/3/2azW0hsC2YQ
http://www.youtube.com/user/V8Vixen1#p/u/4/QKQyaSLObzc
http://www.youtube.com/user/V8Vixen1#p/u/5/eozbSlc0mmI
http://www.youtube.com/user/V8Vixen1#p/u/6/73MyUCYQJiQ
http://www.youtube.com/user/V8Vixen1#p/u/7/YenOwEHtxGo
http://www.youtube.com/user/V8Vixen1#p/u/9/gge8lGu14wg
What happened before…
[url][/url]
Mugen59
MessagePosté le: 20.02.2015, 17:16:39    Sujet du message: Répondre en citant
c'est Top OK! Bravo!
TT 1/8 Mugen mbx6 R
1 thermique + 1 brush
philippe27
MessagePosté le: 20.02.2015, 23:18:10    Sujet du message: Répondre en citant
pour ceux qui aiment les transmissions a chaine a pignon
la il y a de quoi voir
philippe27
MessagePosté le: 21.02.2015, 17:07:16    Sujet du message: Répondre en citant
[url][/url]
https://www.youtube.com/watch?v=SSw50Pj9B24
Gadman
MessagePosté le: 21.02.2015, 21:31:23    Sujet du message: Répondre en citant
ça c'est du 1/4 !!!
L'engin doit peser dans les 250 kg il me semble
Superbe OK!
www.Yankee-RC.com ... YANKEE forever
