RCmag :: Voir le sujet - Exceed RC MadTorque 8×8 Crawler Truck RTR in scala 1/8
philippe27
MessagePosté le: 03.01.2015, 18:34:10    Sujet du message: Exceed RC MadTorque 8×8 Crawler Truck RTR in scala 1/8 Répondre en citant
[url][/url]
The Mad Torque series of RC Trucks veered off normal and arrived at extreme. The new Mad Torque 8x8 is what they have created. This new Mad Torque is a ready to run 8x8 Crawler complete with multi link suspension, 4 solid axles, aluminum chassis, oil filled shocks, and locked differentials. Semi truck front cab with a dump truck rear end ensure the trucks ability to haul large payloads. Designed specifically for the tough demands of traversing gravel, sand, asphalt, snow, wood chips or rocks. Created for the customer who demands more wheels and power to the ground.
The power system consists of twin brushed electronic speed controllers providing power to the four high torque 540 motors. A 7.2v 3300mah Ni-MH Battery delivers about 10 minutes of crawl time. Twin 9kg digital metal geared steering servos steer this beast in the direction you tell it to via an Exceed RC 2.4ghz radio system. This system ensures interference free transmission to connect human to machine.
True bead lock rock crawling wheels clamp onto aggressive rugged all terrain tires ensuring traction and grip in all types of terrain. The Mad Torque 8x8 is ready for any adventure.
Features:
2.4GHz Radio Control
Four 540 High Performance Motor
Twin Waterproof Electronic Speed Controller (Note: ESC supports 6-7 cells Ni-MH battery only)
7.2v 3300mAh Ni-MH Battery
Dual Front-wheel steering
Eight-wheel independent suspension
Fully sealed Ball Bearing set
Oil filled shocks
Multi link suspension design
True bead lock wheels and tires
Advanced Crawler tires tread pattern
High Torque steering servos
Aluminum chassis construction
Specifications:
Length:990CM
Width:360CM
Height:330CM
Wheelbase:230CM
Tread:360CM
Weight:6.34KG
2.4G Radio
4x 540 Brushed motors
2x 20A ESC
2x 9KG Steering Servo
