Posté le: 13.11.2011, 20:26:30 Sujet du message: Amortisseurs spéciaux pour Krawler RC4WD
Killer Krawler Pro Coil-Over Piggy Back Shocks
Killer Krawler Pro Shocks are the latest high performance upgrade for Killer Krawler or similar truck. Lightweight redesigned sleek housing and resevoir, 10mm added length for smooth damping action.
Specification:
# Spring Diameter: 73.26mm (2.884inch)
# Weight: 3.15oz/90g
# Hole to hole (Compressed):3.307inch/84mm
# Hole to hole (Uncompressed): 4.69inch/119.15mm
# Overall length: 5.133inch/130.39mm
# Travel length:3.745inch/95.12mm
# Shock body OD: 1.22inch/31mm
# Shaft diameter: 2.99mm/0.118inch
# Spring overall length:2.884inch/73.26mm
Killer Krawler 125mm Shocks (Gun Metal) (2)
These are 10mm longer shocks for Killer Krawler
