Posté le: 17.05.2014, 11:13:40 Sujet du message: News Dynamite's GPS Speed Meter and Tracker provides car
Part Number: DYN4401
Overview
Dynamite's GPS Speed Meter and Tracker provides car/truck, boating and air enthusiasts with a compact, portable and easy to use GPS device for tracking everything from top speed reached to locations of their model. The unit's compact size and ultra light weight allows for it to be utilized in various applications including everything from large scale aircraft to 1/10th or smaller radio control cars/trucks/boats.
Thanks to the units built-in WASS/EGNOS/MSAS/RTCM (Global Positioning compatibility by country or region), the unit can be used anywhere in the world. The unit uses 10Hz refresh rate providing extremely fast response to changes in the models position while the units low power consumption provides the user with up to 4 hours of uninterrupted tracking time.
The unit's LCD screen provides real-time data feedback and it's waterproof design allows for use in virtually all weather conditions. You can also use the Dynamite GPS Logger* software to map your drive, flight, jog, swim, etc. using Google mapping products.
The LCD screen will display average, current, and peak speed. As well as current and max altitude, total distance, and GPS coordinates.
Features
Track: Location, speed, altitude and much more
Compact size allows for fit easy almost anywhere
Lightweight for almost any RC application
Built-in high-capacity LiPo Battery - 4 hours cont. tracking
USB cable included for charging
PC Interface for mapping on Google map products
Can be used in real-world application worldwide
