TD-2 (Transmitting Devise - 2) #93031
The TD-2 can be used with the Type 3 or Type 2 system. Comes with TD-2 housing iwth built in LED, entry chip and connecting wire (8 in.).
ARC Entry Tag for Mini-Z (#93002)
The entry tag is used to boost the signal from the Mini-Z car with weak signals for the Type-1 system. This is placed directly over the Rx crystal. Comes with 3 pieces.
TD-1 Connecting Wire
The TD-1 connecting wire comes in two lengths. The 8 inch (20cm) is the standard replacement (#93022). Also available in 4 inch (10cm) as a replacement (#93023).
Twin Extension Wire for TD-1 (#93025)
The twin extension wire is an accessory for the TD-1. This is used for receivers that do not have a third channel available or to be used in-between the battery connection.
Entry Chip (#93101~20)
Replacement entry chips are available for the TD-1 or TD-2 by chip number.
High Grade AD set (#15982)
For the MR-02 chassis, upgrade to the AD band. Includes module for the EX-10 Helios, PC board, pot and motor for servo. Settings can be change with the PC interface (optional).
