RCmag :: Voir le sujet - Servos arrow RSx Series kopropo
philippe27
MessagePosté le: 20.10.2010, 12:33:03    Sujet du message: Servos arrow RSx Series kopropo Répondre en citant
For the ultimate racing competition servos we offer the RSx (Racing Servo) Series. These new servos are the product of two years of R&D for both on-road and off-road. The new servo line features all new materials for increased strength and new programming to take advantage of today's current technology.
* Internal Improvements:
The servo gears are cut in house for the best Quality Control from "special Japanese aluminum" for superior hardness and wear. This aluminum is 30% lighter and 20% stronger then steel.
The servo amplifier and processor has been re-worked and optimized for Lipo direct voltage but will still operate when used with NiMH cells.
A new core-less motor for the higher voltage is used to further enhance the use of the Lipo technology.*
* External Improvements:
The middle case is a one piece machined aluminum part to hold the gears properly in place without any plastic insert.
The standard RSx features a new upper case redesigned with increased rigidity on the mounting tabs. The H.C. (Hard Case) versions of the RSx include a machined upper case for maximum rigidity.
RSx Power
VOLTAGE: 6V or 7.4V
TORQUE @6V: 362.9 oz-in, 26.3 Kg-cm
TORQUE @7.4V: 436.1 oz-in, 31.6 Kg-cm
SPEED@6V: 0.13 S @ 60°
SPEED @ 7.4V: 0.11 S @ 60°
BEARINGS: YES, DBL
LEAD CONNECTOR: GOLD PLATED
GEARS: FULL METAL
WEIGHT: 65.6 g
The RSx Response is designed for ultimate rigidity while providing high torque. This servo comes ready to operate at 6V or 7.4V.
Programming of this servo will also be available via PC or ICS setting card for the RSx for further fine tuning.
Recommended for use on steering for 1/8th off-road truggy, throttle for 1/8th off-road buggy/truggy and throttle for 1/8th on-road.
RSx Power H.C.
VOLTAGE: 6V or 7.4V
TORQUE @6V: 200.1 oz-in, 14.5 Kg-cm
TORQUE @7.4V: 242.9 oz-in, 17.6 Kg-cm
SPEED@6V: 0.07 S @ 60°
SPEED @ 7.4V: 0.06 S @ 60°
BEARINGS: YES, DBL
GEARS: FULL METAL
WEIGHT: 65.6 g
The RSx Response is designed to providing high speed. This servo comes ready to operate at 6V or 7.4V.
Recommended for use on steering for 1/8th off-road buggy, 1/8th on-road and all 1/10th scale vehicles.
RSx Response H.C.
OLTAGE: 6V or 7.4V
BEARINGS: YES, DBL
GEARS: FULL METAL
WEIGHT: 70.5 g
The RSx Response H.C. (Hard Case) is designed for ultimate rigidity while still providing high speed. This servo comes ready to operate at 6V or 7.4V.
Recommended for use on steering for 1/8th off-road buggy, 1/8th on-road and 1/10th GP on-road.
