RCmag :: Voir le sujet - OS Speed B2101 Ty Tessmann Edition
philippe27
MessagePosté le: 28.02.2015, 00:03:29    Sujet du message: OS Speed B2101 Ty Tessmann Edition Répondre en citant
A special release of proven World Champion power.
Ty Tessmann tore up the track at the 2014 IFMAR 1/8 Scale Off-Road World Championships running an O.S. Speed Tuned B2101 engine tailored to his winning specs. Now O.S. makes that same setup available to other drivers — in the Ty Tessmann Limited Edition Speed Tuned B2101.
The Limited Edition B2101 features the same tuned pipe, manifold and carb restrictor used by Ty to win the 2014 IFMAR Championships. Its T-2090SC pipe is paired with an M2002SC manifold whose added length increases torque in the low to middle range. The 5.8 mm restrictor — not available on any other O.S. engine — matches what O.S. supplied to Ty for extending run time in competition.
Like the standard B2101, this version has a lowered cylinder head; DLC crankshaft with balanced tungsten weights; and efficient, reliable Type 21J carburetor. The design provides stability, predictable handling, instant response and rapid acceleration.
Only a small number are being produced, making this engine both competitive and collectible. The Ty Tessmann Limited Edition Speed Tuned B2101 is easy to distinguish from the standard model. Look for the natural-color cylinder head and Ty's name laser-etched onto the crankcase, crankshaft and tuned pipe.
• Tailored to Ty Tessmann's IFMAR-winning specs!
• Lowered cylinder head and DLC crankshaft with balanced tungsten weights.
• Ty Tessmann's name is laser-etched on the crankcase, crankshaft and T-2090SC tuned pipe.
"I compete in major races all over the world, in all kinds of conditions. Many things can go wrong, but I never worry about my O.S. engines. They're powerful, driveable and consistent."
— Ty Tessmann, 2014 IFMAR 1/8 Scale Off-Road World Champion
• Specifications
• Parts Listing
• Accessories
• Gallery
Stock Number: OSMG2044
Displacement: 0.211 cu in (3.46 cc)
Bore: 0.646 in (16.40 mm)
Stroke: 0.646 in (16.40 mm)
Practical RPM: 4,000-42,000
Output: 2.61 hp @ 34,000 rpm
Weight: 12.42 oz (352 g)
Includes: 21J carburetor; 5.8 mm carb restrictor; T-2090SC tuned pipe; M2002S manifold
Requires: Glow fuel
http://www.osengines.com/engines-car/osmg2044/index.html
http://downloads.hobbico.com/factsheets/osm/osmg2044-fact-sheet.pdf
philippe27
MessagePosté le: 28.02.2015, 00:08:19    Sujet du message: Répondre en citant
topgeorges
MessagePosté le: 28.02.2015, 18:30:13    Sujet du message: Répondre en citant
eeuuuhhh c'est plus une nouveauté ça fait déjà quelques temps qu'il est en magasin Embarassed Embarassed Embarassed
philippe27
MessagePosté le: 02.03.2015, 20:13:05    Sujet du message: Répondre en citant
https://www.facebook.com/video.php?v=10152716682178807
Cronux
MessagePosté le: 02.03.2015, 21:04:08    Sujet du message: Répondre en citant
J'ai eu la chance de recevoir mon moteur il y a 2 semaines, c'est un vrai bijou.
