The Botmobile Dune Buggy is an open source 3d printed remote control car that you can build at home. This awesome kit requires no soldering, all the parts snap together. It's a perfect weekend project. And if you want to change it or customize it? The design files are open source and ready for you to turn it into a hot rod.
Included in the kit:
12 VDC motor with attached JST female connector cable.
2 -channel 2.4GHz transmitter with servo reversing.
3 -channel receiver
1 -micro-servo motor
20A Electronic Speed Controller with reverse
4 -rubber racing tires
2 -608 skateboard size bearings
4 -AA battery holder with attached JST male connector cable
Download and print the body from Thingiverse free! (link)
